EagleRiderPerformanceOilTechCheapCycleParts.comProCharger.comLawTigersRosa's CycleTech N' Cycle GearRacerPartsWholesaleHD PipesDaytona Twin-TecArnottAirRideSportbikeTrackGear
HD Pipes
Old 05-16-2008, 04:19 PM   #406 (permalink)
FatBoy912 is on a distinguished road
Originally Posted by ceraaa42 View Post
FWIW, you might want to read the thread in the dealer experiences forum about American Classic.
Chris
I bought my exhaust from them because no one could beat the price and free shipping, arrived in a week with no issues, now after reading the thread I may chalk it up to luck the first time and look into someone else. Thanks for the heads up Chris, much appreciated.
Tate
FatBoy912 is offline   Reply With Quote
Old 05-16-2008, 10:26 PM   #407 (permalink)
Jaybo is on a distinguished road
Originally Posted by alanmcgregor View Post
Seperate question. I don't like that dead feeling on decel when the throttle is closed. On the V&H site they suggest increasing mode 23. Presumably this puts a little more fuel in on decel. Has anyone tried this and how far did you increase, mode 23, and did it work?
Cheers
Alan
Hi Alan. I have an 08 Road King with V&H ovals, true duals and, of course, the fuel pak. Mode 23 is one of those modes I have played around with in the past in an attempt to eliminate decel popping. My experience has been as follows:
As the value of mode 23 is decreased the so called "Dead" feeling increases. Vance and Hines claims that this action cuts the fuel to the injectors a lot sooner as you close your throttle. As a result of making this adjustment, decel popping went away. However, I did not like the increased "Dead" feeling, so I decided to make an adjustment in the opposite direction. The "Dead" feeling went away, but decel popping returned. I eventually decided to leave it at the manufacturers recommended setting. I've gotten so use to the "Dead" feeling during decel, it doesn't even bother me anymore. I've put 3,000 miles on the fuel pak since then and the scoot still runs and performs beautifully. As far as the "Dead" feeling being harmful to the engine, there is no evidence that this is the case. I hope this helps.
Please post your results after experimenting.
Jaybo is offline   Reply With Quote
Old 05-16-2008, 10:56 PM   #408 (permalink)
racerdave's Avatar
racerdave is on a distinguished road
Can some give a better description of this "dead" feeling?
Proud supporter of the SaintLouis Cardinals. More World series titles than any other National League team.
racerdave is offline   Reply With Quote
Old 05-17-2008, 05:08 AM   #409 (permalink)
alanmcgregor's Avatar
alanmcgregor is on a distinguished road
Jaybo
Thanks. Very helpul. I do have some poppoing on decel and it does go away when when the fuel shuts off. Sounds like if I increase 23 then I can expect popping for a bit longer.
My concern about the engine was that is shutting off the fuel not the equivalent of running super lean for a short period? Perhaps it doesn't matter because the engine is not under any load when the trottle is closed?
alanmcgregor is offline   Reply With Quote
Old 05-17-2008, 05:14 AM   #410 (permalink)
Imagine coasting downhill and switching the ignition off while still in gear. Doesn't last long and the fuel comes back smoothly though.
I just find it a bit distracting and disconcerting!
Old 05-17-2008, 05:18 AM   #411 (permalink)
How much did you increase mode 23 by - number?
Old 05-17-2008, 08:00 AM   #412 (permalink)
hellboundpig is on a distinguished road
can you run aftermarket pipes and aircleaner with stock ecu settings was running with the
fuelpack removed today bike ran great no decell pop ran cool .2007 softail standard vance and hines bishot staggereds k&n aircleaner .
hellboundpig is offline   Reply With Quote
Old 05-17-2008, 05:25 PM   #413 (permalink)
streetglide1 is on a distinguished road
fuelpac
Doe's Eastern performance still sell the fuelpak?If not were's the best place to get one.
streetglide1 is offline   Reply With Quote
Old 05-17-2008, 07:34 PM   #414 (permalink)
Striker's Avatar
Striker is on a distinguished road
Hi All,
Does the fuel pack actually fit the Fat Bob? After hours in the garage and looking at the installation video mine will not fit under the ECU. It's half past midnight and I'm giving up.......for now.
Cheers,
Andy
Striker is offline   Reply With Quote
Old 05-17-2008, 09:00 PM   #415 (permalink)
Mode 23: up 16 ---> 17
down 16 ---> 15
I could tell a big difference when adjusting by just one value in either direction.
Old 05-17-2008, 09:28 PM   #416 (permalink)
ol'phart
xandvphyle's Avatar
xandvphyle is on a distinguished road
I ordered mine from them a few months ago and they got it to me quickly.
bob
2007 FLSTSC
mechanics; SE Pipes and K&N and SE housing with stage one download, V&H fuelpak
add ons; a few for eye candy; a few for function
Amsoil in all mechanical orifices!
goin' on 33
xandvphyle is offline   Reply With Quote
Old 05-18-2008, 04:00 AM   #417 (permalink)
Are we having FUN yet?
Jeffytune's Avatar
Yes they do.
I'm Just Sayin'...
2007 FLHT 96 CID W/IDS drive
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
93.25 Torque 78.74 HP
Professional Rockat Surgen
Disclaimer.
Old 05-18-2008, 04:08 AM   #418 (permalink)
Jeffytune's Avatar
Originally Posted by Striker View Post
Hi All,
Cheers,
Andy
Hi Andy,
I believe it is made to mount on top of the ECU, not under it.
I find that if you trim the mounting screws (The ones for the Fuelpak mounting bracket to unit) it goes a bit smoother.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 05-18-2008, 04:11 AM   #419 (permalink)
Jeffytune's Avatar
Alan.
It is just the way it is design to work, really it's not a issue.
Give it a bit of riding time, and you won't even notice it.
The fuelpak shunts the injectors on decel.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 05-18-2008, 05:15 AM   #420 (permalink)
Striker's Avatar
Originally Posted by Jeffytune View Post
Hi Andy,
Thanks for the reply Jeffytune,
I've done it this morning, looking at the video again the space was not free below the ECU on my bike, a 3"x2" box of tricks (maybe the alarm) was in the way so I moved this and I got it fitted.
I've taken off the servo for the exhaust flap and removed the cable. I have also tack welded the flat open.
I used ref FP-2075
I'm running a HyperCharger, Rush Slip On's.
Thanks again,
Striker (Andy)
2007 Fat Bob.
You may not edit y
