KewlMetal.comRosa's CyclePerformanceOilTechAdvanstarMotorcycleShowsMotorcycle.comHD PipesProCharger.comLawTigersBikeBandit
LawTigers
Old 04-20-2008, 05:39 AM   #361 (permalink)
HDRoadkng is on a distinguished road
Originally Posted by Ultra RB View Post
Maybe I'm opening a can of worms here but ...
By installing a FuelPak, SE air cleaner and V&H Oval slipons on my new 2008 Ultra ... did I just void the warranty?
Thanks,
RB
I did the exact same thing on a 08 Road Glide except I went with the Big Radius. I ran into a problem and the dealer I use said if the after market product caused the problem then the warranty wouldn't cover the repair. Of course they first said the Fuelpak was the problem, and I had to argue with them to road test without the Fuelpak (they just used the diagnostic tools) and it turned out to be the ECM. They replaced the ECM and I was back in business.
Stan
HDRoadkng is offline   Reply With Quote
Old 04-20-2008, 05:48 AM   #362 (permalink)
Originally Posted by Jeffytune View Post
Hi Stan.
Thank you for sharing this info with us, I would bet that my boss had the download done when they did his 103 kit, and dyno tuned it with the SERT.
I called my friend at the dealer, they have not been made aware of this upgrade as if yet, but the northwest it seems is the last to get anything.
He said he would call the company tuesday and get back to me.
Jeffy,
Thanks again, I'd really like to hear what the company tells your friend. The local dealer Adamec, called me back late yesterday and said they have never heard of the issue. But Rossmeyer did I just dont' get it. I know some say they get used to it but with mine there have been several times I hit the throttle (yes I like to hit hard at times.. )and it feels like I'm starting it second or third gear because of the lag.
Thanks again.
Stan
Old 04-20-2008, 04:08 PM   #363 (permalink)
Are we having FUN yet?
Jeffytune's Avatar
Originally Posted by HDRoadkng View Post
Jeffy,
Thanks again.
Stan
If I were to take a guess at it, I would say they (The MOCO) have this for Police bikes, and are using it as a test fleet before releasing it to the customer base.
I'm Just Sayin'...
2007 FLHT 96 CID W/IDS drive
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
93.25 Torque 78.74 HP
Professional Rockat Surgen
Disclaimer.
I do not work for Vance and Hines, I just like there stuff. Any suggestions I make are to be use at your own risk.
Old 04-24-2008, 09:14 PM   #364 (permalink)
hellboundpig is on a distinguished road
vance&hines fuel pack
Hi all.
The stated idea of this post(I hope to be a sticky) is to have a place here to exchange Ideas and advice on the Vance & Hines Fuelpak.
Now, I know that many here have some strong opinions on the fuelpak, and if you don't care for it, and you prefer another system, then good for you, and please move along, wechanged in the post are going to try and help and advice those of us that have chosen to use this system, and unhelpful post will be asked to have removed.
So, please. lets all use this as a resource to help other and ourselves with this simple to use system.
Exchanging program Ideas and experiences.
Hi I have a 2007 softail standard fuel pack vance&hines bigshot stagards and k&n aircleaner changed mode 23 to 16 to 15 no exhaust leaks still get a decell pop any ideas cheers.
hellboundpig is offline   Reply With Quote
Old 04-25-2008, 07:14 PM   #365 (permalink)
Jeffytune's Avatar
Hi.
Ok, if there are no leaks, then i would look to see if you have a small inatke leak, assuming that is ok, then have a local dyno tuner do a basic run and have the results looked over at Vance and Hines.
Just e-mail it to them, and they can tell you if there are any adjustments needed.
There real good about doing this for us for free.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 04-29-2008, 07:19 PM   #366 (permalink)
downhomer is on a distinguished road
Hi. I just installed Reinharts true duals to my 2008 FLHTCU and noticed sputtering, popping, stalling, backfiring and lagging power. I ordered and installed the appropiate V&H fuel pack thnking this would solved the problem. Unfortunatly, It has got worse and I have little or no power on the highway. I checked for intake leaks and made sure the pipes were secured properly to the intale flanges. Any suggestion??
downhomer is offline   Reply With Quote
Old 04-30-2008, 12:04 AM   #367 (permalink)
Jeffytune's Avatar
Hi.
What type of air filter did you install?
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 05-04-2008, 07:53 AM   #368 (permalink)
Do the first 3 or 4 settings inrichen and lean for zero throttle roll off I have been adjusting these settings and it seems to help clear up the decell gurgle and popping.
Old 05-04-2008, 11:03 PM   #369 (permalink)
The story of my life!
ceraaa42's Avatar
You probably won't get an answer to your question here. This info is held tightly at V & H, as they don't want to see you mess with it, and accidentially lean out your engine until you have damage. They will talk to you if you call and might give you some info on what to change to help.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
"Ya fargin' sneeky bastage!"
43 member
Old 05-04-2008, 11:25 PM   #370 (permalink)
Jeffytune's Avatar
I couldn't say yes or no, they won't tell me either.
All I can say is, Vance and Hines is very good at help there customers adjust it, BUT they want to be the ones to control the adjustments.
And, yes, they do this for FREE......what more could you ask for?
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 05-05-2008, 02:02 AM   #371 (permalink)
simijim is on a distinguished road
Which way to go
I pick up a 2008 Softail Deluxe and after the first ride know I am going to change pipes. Reading several forums on EFI tuning and expence to tuning I am leaning towards the FuelPac. Reading your comments it would appear V&H give a lot of suport to their product. I had thought about SE race tunner but I do not have acces to a Dyno
I am going to go with V&H duals, SE A/C and thats about all in mods I plan to do. Has any one been runing the duals with fuelpac on a Deluxe?
simijim is offline   Reply With Quote
Old 05-05-2008, 02:13 AM   #372 (permalink)
Jeffytune's Avatar
I have found V&H to be a very supportive and fairly fast to respond company.
If all you plain to do is the pay the tax, stage one, the fuelpak is a far better way to go.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 05-05-2008, 08:36 PM   #373 (permalink)
Shriner Jim is on a distinguished road
Jeffytune:
My ride is an '08 Ultra Classic. It was HOT right out of the box. I kinda liked the Nightrider.com Wide Band O2 Sensor upgrade. I did that and my fuel mpg went from 39-40 to about 38. This was no big deal, however the bike didn't sound harley enough. I put on Rush slip-ons, 2" baffle. I immediately popped on decel. My right leg still burns on a hot day.
I ordered V&H true duals, K&N air filter and a V&H Fuelpak. I don't have them yet, my ebay salesman is a bit sluggish.
Do you think that I can leave the Nightrider fix on? Nightrider.com says it is compatible. If I can leave it on, why should I......Thanks in advance for your opinion.
Shriner Jim
Shriner Jim is offline   Reply With Quote
Old 05-07-2008, 06:10 AM   #374 (permalink)
OK, anybody else out there have an opinion about LC-1 vs. Fuelpak?
Old 05-07-2008, 10:35 AM   #375 (permalink)
Ultra RB is on a distinguished road
Question Popping on deceleration, throttle lag, Fuelpak, 2008
2008 Ultra, stock ECM, SE air filter, V&H Oval slip-ons, 61009 FuelPak, FP-1717 map.
Problem one was the lag in the throttle when starting off. V&H rep suggested changing mode 1 to 7 and mode 5 to 25 .... this has not eliminated the problem but helped a lot.
Problem two is popping on deceleration. V&H rep suggested changing mode 23 to 15 ... this helped but the amount of popping is still excessive. On another call to V&H they suggested that they could not adjust mode 23 any further down as it would result in engine stall on longer hill decelerations. The suggested that open exhaust systems tend to pop ... I suggested that this was not the case on my 95" build on my previous Ultra with a similar setup. Bottom line was there was nothing further they could adjust and to live with it.
Any suggestions on the decel popping issue?
Thanks,
RB
'08 Ultra Classic
Black
Ultra RB is offline   Reply With Quote
You may not<
