Motorcycle.comStoneyStraps.comPowersportModels.comRosa's CycleArnottAirRideRacer SupplyPerformanceOilTech
KomodoGear.com
Old 04-18-2008, 05:14 PM   #346 (permalink)
tatertot is on a distinguished road
Thanks, I'll give them a call. Given the info I gave, does it sound like a lean condition?
tatertot is offline   Reply With Quote
Old 04-18-2008, 08:52 PM   #347 (permalink)
Are we having FUN yet?
Jeffytune's Avatar
A pop can be caused by a lean run, but it can be a rich run too.
It can also be the way you work the throttle, how hard you were on it before you shifted, and if you are closing it during the shift.
With all that said, most tuners i know that do Power commanders and SERT tuning do not guarantee the exhaust will not pop, it can be a function of the free flow exhaust system.
I'm Just Sayin'...
2007 FLHT 96 CID W/IDS drive
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
93.25 Torque 78.74 HP
Professional Rockat Surgen
Disclaimer.
I do not work for Vance and Hines, I just like there stuff. Any suggestions I make are to be use at your own risk.
Old 04-18-2008, 08:57 PM   #348 (permalink)
Have no popping with shift changes, only with decel when coming to a stop or slowing down when I let off the throttle.
Old 04-19-2008, 07:22 AM   #349 (permalink)
HDRoadkng is on a distinguished road
I can't remember
While reading and posting to this thread a month or so ago I think I recall seeing someone mention the issue with the throttle lag on 08 fly by wire. I thought I also read there is a download out there. Does anyone recall or have any dealings with the issue. I know this isn't the appropriate thread for this post but thought I'd try here first, so keep the flame to a low heat.
Stan
HDRoadkng is offline   Reply With Quote
Old 04-19-2008, 11:14 AM   #350 (permalink)
Jeffytune's Avatar
Stan
I have a 2007, but my boss has a 2008, he choice to use the SERT over the Fuelpak. He and I are both master techs in the auto repair world, and electric throttle is nothing new to us, it has been on cars for over 10 years now.
Stan, I am unaware of a download to speed up the throttle response, and after riding my boss's 2008, all I can say is, yes there is a heart beat delay, but so does every car I have driven with it.
He said that after a month of riding he doesn't even notice it any more.
If the delay is one that is very noticeable, then I would have the dealer look into it, as that would not be normal, it should be something that you can easily get used too.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 04-19-2008, 11:26 AM   #351 (permalink)
Jeffytune's Avatar
Do you totally shut the the throttle on decel?
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 04-19-2008, 12:31 PM   #352 (permalink)
Jeffy,
Thanks, I'm not the only one who has experinced this problem. I was told by a motorcycle cop with the St. Augustine Fl Sheriff's department of the same problem. They took their entire fleet of 08 bikes to Bruce Rossmeyer's in Daytona who upgraded their ECM's program. Anyway, I made a call to Adamac, the local dealer here who said they never heard of the problem or download. I then called Rossmeyer's who reluctantly admitted there is a new ECM program that will correct the program. He said it takes the ECM from a C to a D version. He said that dealer's are suppose to check on the 1000 mile service what program is in the ECM and upgrade as necessary. As interesting side note the deputy who told me of the problem said that after the upgrade you have to reload a Stage One download if you had it prior to the upgrade. He went on to say that at first Rossmeyer was going to charge the county for the remap of the Stage One until the Sheriff made a call.
Btw I never doubted your experince or knowledge.
Stan
Old 04-19-2008, 05:30 PM   #353 (permalink)
Jeffytune's Avatar
Jeffy,
Stan
Hi Stan.
Thank you for sharing this info with us, I would bet that my boss had the download done when they did his 103 kit, and dyno tuned it with the SERT.
I called my friend at the dealer, they have not been made aware of this upgrade as if yet, but the northwest it seems is the last to get anything.
He said he would call the company tuesday and get back to me.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 04-19-2008, 06:50 PM   #354 (permalink)
The story of my life!
ceraaa42's Avatar
Stan
With mine, if you were to sit at idle and work the throttle back and forth you will feel the lag. As I just ride it, I NEVER feel it. Also I'm not out there wacking the throttle to wide open from a low rpm either.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
"Ya fargin' sneeky bastage!"
43 member
Old 04-19-2008, 07:08 PM   #355 (permalink)
Yes The popping occurs when decel and using the engine as a brake. Doesn't happen when I pull in the clutch and off the throttle.
Old 04-19-2008, 07:09 PM   #356 (permalink)
Chris
Same with my 2008. Takes a litte getting used to.
Old 04-19-2008, 09:15 PM   #357 (permalink)
Ultra RB is on a distinguished road
Arrow Warranty ...
Maybe I'm opening a can of worms here but ...
By installing a FuelPak, SE air cleaner and V&H Oval slipons on my new 2008 Ultra ... did I just void the warranty?
Thanks,
RB
Ultra RB is offline   Reply With Quote
Old 04-20-2008, 01:17 AM   #358 (permalink)
Kauai_Jim's Avatar
Kauai_Jim is on a distinguished road
Just depends on your dealer from what I've seen!
Kauai_Jim is offline   Reply With Quote
Old 04-20-2008, 01:26 AM   #359 (permalink)
Jeffytune's Avatar
Thanks,
RB
HI.
From what I have seen, it shouldn't. If the dealer gives you a hard time, just go strait to the factory district representative.
The factory is the only ones that can void a warranty.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Old 04-20-2008, 01:32 AM   #360 (permalink)
Jeffytune's Avatar
It is best for the engine to use the brakes to stop, the forced decel can, in extreme cases, shift the flywheels.
That and suck your fuel mileage, wear out the clutch and increase wear on the transmission.
That is not to say that wile riding through the twisties you should not engine decel to control the bike, it's the down shift to stop as the norm that becomes a issue.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
Linear Mode Linear Mode
