» Buyers Guides |
07-26-2007, 05:51 PM
#16 (permalink)
Originally Posted by Jeffytune
that is why I suggest if you have a Issue, get a standard dyno run with temps and throttle openings and send it to V&H, they can correct the program to your bikes needs.
Are the temps and throttle openings something you get with a dyno run??? Or is it something you have to request??? I have zero experience with dyno runs. There is a dealership around here that does $20 runs a couple of times a year. I am getting ready to get a fuelpak and like the idea that I can have my settings fine tuned.
07-26-2007, 06:10 PM
#17 (permalink)
Are we having "FUN" yet??
It is something you need to ask the tech for, usually, they can do this without and problem.
The more Info you can give them, the better they can dial it in.
I'm Just Sayin'...
2007 FLHT 96 CID W/IDS drive
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
93.25 Torque 78.74 HP
Professional Rockat Surgen
Disclaimer.
I do not work for Vance and Hines, I just like there stuff. Any suggestions I make are to be use at your own risk.
07-26-2007, 06:35 PM
#18 (permalink)
Is there any other info I could ask for that would help in getting a better fine-tune???
07-27-2007, 08:06 PM
#19 (permalink)
you are a genius
 V&H marketing "you are a genius"...doesn;t seem like a whole lot of genius' are posting on this one except Jeffytune. If I had to guess, i'd say jeffytune must be on V&H payroll.......just sayin'
I really don't think it's a bad product, just wish there was more info....
07-29-2007, 11:06 PM
#20 (permalink)
Once again, I do not work for or have an affiliation with Vance and Hines, I just like there products and am trying to help others if there is an Issue.
I have ben doing automotive FI for 30 years, and Delphi (GM) makes Harley set-up, so I know the system to point.
The Point you make is a good one, and in most cases, the program the booklet has work just fine, it's when it has an Issue that I can help you use these steps to help them help you.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
07-29-2007, 11:09 PM
#21 (permalink)
The dyno sheet itself should show the Temp and humidity and what correction they are using, but almost all do put this on the print out.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
09-03-2007, 11:09 AM
#22 (permalink)
I'm getting the Fuel Pak with a D&D Fat Cat and Big Sucker for my 07 Softail Deluxe. They don't have a map just for that setup. Do you think the Thunderheader map would work?
My first post on this forum. Hello to all!
09-03-2007, 04:47 PM
#23 (permalink)
I bought A 2005 ultra . It has Screamin Eagle slash down pipes, High flow A/C . And I was told it has the stage 1 down load . I bought A fuel pak . And it dosnt list what I have with stage 1 , Only stock .
So am I screwed ? Why would Vance & Hines have some maps for some stage 1 and others they dont ?
Any suggestions ? I did email them but have not heard back from them yet .
My bike does alot of backfiring on decell , And coughs/backfire ? or something between shifts.
And slight surge at slow steady speed .
Jack
09-03-2007, 06:04 PM
#24 (permalink)
I ride, therefore I am.
'06 Street Bob, V&H Straightshot mufflers, V&H Fuelpak, K&N kit.
Used the stock numbers from the V&H documentation for the fuelpak. Bike runs well. No starting issues, no popping, sounds great.
I'll probably dyno it someday out of curiosity but feel no need to.
2008 FLHT, V&H Duals (16737), V&H Ovals (16727), V&H Fuelpak (61009), SE A/C (29260-08).
09-04-2007, 12:13 AM
#25 (permalink)
Hi.
Use this link here.....
http://www.fuelpakfi.com/harley1.html
It will ask you to put the info from your bike, and your e-mail.
Use the other when you get to exhaust and give them all the info you can.
It then goes to V&H's tuning shop and in a couple days they will send you a map for your bike.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
09-04-2007, 12:24 AM
#26 (permalink)
Jack
Hi Jack.
Well, I didn't have a problem finding it, here you go.
It is FP-0386 in your book.
You can double check in on Vance and Hines fuelpak site.
I'm Just Sayin'...
GMR Roller rockers.
Disclaimer.
09-04-2007, 03:54 AM
#27 (permalink)
Hi.
wrong quote
09-04-2007, 03:58 AM
#28 (permalink)
Hi Jack.
I quoted the wrong post , Sorry bout that .
But I have A stage one download . And this is for stock ECM .
Jack
09-04-2007, 06:06 PM
#29 (permalink)
Recieved an email from Adam Rogers
Fuel Pak Technical Support. And they suggested FP-0384.
Thank you
Jack
09-05-2007, 06:23 PM
#30 (permalink)
Okay lookng at something else for the mistress. Mainly like to get a little more bang if possible without the high cost of doing a full 98 kit etc. Thats in the future but need to save a bit more.....LOL
So do I go Power commander or Fuelpak? Will either give me a bit more oohmpf?
06 Heritage, with SE Pro II slip-ons, SE air filter did the upgraded ECM via dealer basic Stage I.
So looking for opinions.
thanks
