12-02-2012, 06:43 PM
#16 (permalink)
Originally Posted by BUBBIE
I said IT didn't run HOT at that lean setting of 15...
That is the purpose of the gen4, getting good Cruise mileage.
You can set it lean on YOUR bike and try for mileage.
Go read about it as they pay to have their product on this forum...
Lean and Running too lean are Not the same.
signed....BUBBIE
Added:
Never was it running TOO lean at 15 AFR
Not familier with this Gen4, is there WEB SITE ON THIS SYSTEM ?? Thanks
 2002 FLSTS, 2005 FLHT
12-02-2012, 07:57 PM
#17 (permalink)
Saved by Christ
When all is said and done...take a close look at TTS and Fullsac.com
I am going with with their headpipe but will take it to Doc's Performance Tuning in Fl for the TTS and tuning...
 2013 RoadKing...Midnight Pearl...ABS,Cruise & Security...SlipStream Collection...440 HD 12"...Fullsac headpipe...CVO slipons w/2" Fullsac cores...Limited Wheels...
12-02-2012, 08:33 PM
#18 (permalink)
Seasoned,Retired Rider
If you can read and have a decent laptop take a good look at the TTS,very easy to ride and tune with IMO. High quality and you can usually buy one for 425.-450.
2012 Ultra Limited,V&H VO2 Intake,Wood 222 Cams,Cobra Power Port Header,CVO Mufflers,TTS Tuner
AMSOIL DEALER SINCE 1985
12-03-2012, 12:33 AM
#19 (permalink)
I went with this, no "tuner" person required. There are some good threads about it on the various hd forum sites. I'm happy with it. Bought it from fuelmoto.
2008 Ultra, SE255 cams, 68T rear sprocket, Revolution Performance Precision EMS, 4" Jackpots (for now)
http://www.revperf.com/Precision/index.html
12-03-2012, 04:28 AM
#20 (permalink)
Dobeck's Gen4 link
This is off their site.
http://www.dobeckperformance.com/GEN...technology.asp
see IF this works for the information you want.
signed....BUBBIE
12-03-2012, 08:36 AM
#21 (permalink)
edit to Added link:
signed....BUBBIE
Added:
How did you verify your temperature at the 15 AFR setting? Did you use an IR temp gun and shoot the head by the base of the spark plug, just going by feel and a WAG? I'm not biting, if you could run 15 afr at cruise and not be hot the MoCo would be all over that and make every bike run there.
This Dobeck thingamabob may be great for someone who is into a quick band aid that gets halfassed close, I'm not into band aids. I'd go TTS or Power vision and get it on a dyno or spend the time to tune it yourself, might learn a thing or too about FI and your engine.
They could give me one and I wouldn't run it on my bike, it would be thanks but no thanks.
2012 GL1800... Seeing how the other side lives  .
12-04-2012, 11:17 AM
#22 (permalink)
Hey guys thanks for all the great info. Decided on the PowerVision for tuner, decided on Andrews 48H cams. Looking at either SE adjustable rods or FuelMoto adjustables. I know SE had nut breakage problems & loosening off problems, they say new ones are good.What about FuelMoto's, anyone use them. The bike has 30,000 km or 22,000 miles should I change the lifters as well. Thanks again
12-04-2012, 05:18 PM
#23 (permalink)
Ironbutt
I would change the lifters with that mileage. I had some SE adjustables a few years ago and they were crap. Don't know if the design has changed or not. Don't know anything about FuelMotos rods. I used Baisley rods for my last build. http://www.baisley.com/twin_cam_pushrods_product.htm
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
12-05-2012, 10:28 AM
#24 (permalink)
I have used SE slender tapers for years and in many different bikes (mine and others).
I and they did not have any problems with any of them.
Not even when they? Said "cracking lock nuts" Not on mine.
I think a lot of problem is on the Installer,,,Not the product.
signed....BUBBIE
12-05-2012, 10:44 AM
#25 (permalink)
We recommend the Dynojet Power Vision, not just because we sell it in our catalog, but because we have created and are creating new tune files everyday. We are creating tune files that work with our cams, intakes, exhaust, big bore, and head kits. Tune files are free and we also offer the best free tech advice in the industry!
Check out
http://www.sscycle.com/software/power-vision/
we are updating this all the time with new files.
12-05-2012, 11:26 AM
#26 (permalink)
Doc's
Doc's has a good rep, lucky for you that you are able to take advantage of proximity and have a A+ tune on your bike.
12-17-2012, 08:29 PM
#27 (permalink)
I have used Scream Eagle quick install adjustable pushrods on 2 bikes with no issues!
I run the PCV with Auto-Tune and love it! Great product and great tech support!
Regards,
mmesa005
09 VRSCAW, 02 FLHRCI 95" Stage II, TW21 Cams, SuperTrapp SuperMeg 2 into 1, SE Cam Plate / Oil Pump / Adj Pushrods, PCV w/Auto-Tune
12-19-2012, 04:19 PM
#28 (permalink)
I use the RC Components RCX-celerator. It's an auto tuner that has worked flawlessly for the 6 months I have had it.
'08 Ultra Classic (sold)
'12 Ultra Limited, Vivid Black, pipes, Big Sucker A/C, RCX-celerator tuner.
| Sponsored Links |
