Effecting Oxygen Sensor output : V-Twin Forum: Harley Davidson Forums
Old 07-12-2010, 04:04 PM   #1 (permalink)
Comingapart wants to know Dino or Syn?
Just me thinking here, if the only A/F measurement these bikes are using is oxy sensors, can't the fuel mixture be adjusted by simply altering the oxy. sensor signal?
Something as simple as unplugging the o2 sensors and replace them with a resistor? Or a simple circuit with a pot to have an adjustable range?
Or, the ideal situation may be to place a resistor inline with the o2 sensor to simply reduce the output by a small margin, that way there would still be some tuning changes to account for temperature.
Provided this would work, any idea how I could figure out what resistor values to use, without having access to any way to measure A/F Ratio?
Comingapart is offline   Reply With Quote Quick reply to this message
Old 07-12-2010, 04:10 PM   #2 (permalink)
Premium octane member
TXCHOP's Avatar
http://nightrider.com/
Much debate over these though...
S&S T124
Old 07-12-2010, 05:20 PM   #3 (permalink)
check out the mustang and camaro sites. they were doing that 15-20 years ago for closed loop. they also altered fuel pump pressure, moved iat to cooler locations, etc tricked ets to keep in open loop------- that was for the guys that didnt tune.
Old 07-13-2010, 09:21 PM   #4 (permalink)
>>> The Curmudgeon <<<
barrybasinger wants to know Dino or Syn?
O2 sensors are actually little "batteries" that produce rapidly fluctuating voltage depending on the amount of residual oxygen in the exhaust moving through their pumping chambers. You couldn't just replace them with resistors. A resistor could possibly be used in the signal line to limit the max amplitude of the "swing", which would tend to make the controller think it was leaner than it actually was. Trick, as you say, would be to figure out how much to trim.
The sensor controller expects the output of a narrow-band sensor, which is a more limited range of voltage fluctuations. If you trimmed below what the controller thought was the minimum voltage to be expected, it might get confused???
Don't know much about Mullens' (nightrider.com) XIED or whatever he ended up calling it, but I'd be interested to know how he got around that problem--if it ever was one. Or did he eliminate the O2 sensor altogether, as others do?
Trouble with all strategies like this is they only correct in one direction. These bikes are lean in some areas, but rich in others. Ideally, you need to be able to add and subtract fuel at various load points. Seems to me that all you're trying to do is the most basic of "add" fuel trimming operations. If that's true, you could just to buy a cheap add-on and get the results you're looking for. Actually, any of them will do that for you.
As far as I'm concerned anyway, there is no way to effectively tune an EFI bike without a dyno, or at least an on-the-road data logger. Anything else is just a guess. (Yes, some are better "guessers" than others, depending on their experience with a particular bike combination).
BB
You may find this interesting:
https://sites.google.com/site/harleyrealstreet/
Five Simple Rules:
- Free Your Heart From Hatred
- Free your Mind From Worries
- Live Simply
- Give More
- Expect Less
"Livin' Dreams and Makin' Memories"
Brian C. Basinger 1944 - 2011
R.I.P., Bro'
barrybasinger is offline   Reply With Quote Quick reply to this message
Old 07-14-2010, 10:38 AM   #5 (permalink)
>>> The Curmudgeon <<<
Above I wrote "...A resistor could possibly be used in the signal line to limit the max amplitude of the "swing", which would tend to make the controller think it was leaner than it actually was...".
I knew after I sent my answer that there was something about it that bothered me, but it wasn't until last night that I realized what it was.
The O2 sensor output is a variable amplitude signal all right, but it is directly proportional to the amount of O2 (sorta) in the exhaust. In other words, higher amplitude with a lean (or unburned) mixture, and lower with a richer mixture. Adding the resistor would make it think it was rich, not lean.
Got my signals crossed (pun intended). Sorry.
BB
Five Simple Rules:
- Live Simply
- Give More
- Expect Less
R.I.P., Bro'
Old 08-07-2010, 09:16 PM   #6 (permalink)
bamofo666's Avatar
Location: Everywhere (Motorhome & enclosed bike trailer)
bamofo666 wants to know Dino or Syn?
"Adding the resistor would make it think it was rich, not lean."
True but what about using a 12v source and using a resistor to bring it down to .9v for 12.0-1 AFR.
Also, doesn't removing the sensor automatically change the AFR to 12.0-1 as stated below?
"During engine warm up the HD engine runs in open loop mode at a 12.0:1AFR. No matter what the engine temperature, this is the AFR that occurs at starting. If you disconnect the O2 sensors on the engine, this is the default idle AFR for the HD engine."
Can anyone verify the accuracy of the statement above? I am using 02 eliminators and it doesn't seem to be the case on my bike. I can't imagine I'm at 12.0-1 and generating the heat mine does at idle.
Also, my bike, no matter how hot, has never done this.
"In high temp mode the engine RPMs drops to 950 and the ECU goes to open loop mode, richening the fuel mixture to 12:1 in an attempt to cool the engine. As soon as the engine RPMs hits 1200, the ECU goes back to closed loop mode at 14.7:1 which is too lean. This means that the smallest amount of throttle will lean the engine out as long as the ECU is operating in "high heat" mode."
(source)
http://www.nightrider.com/biketech/hd2007HD_heat_00.htm
2008 Dyna Lowrider
Stage II 103 kit
w/SE 255 cams
T-Max Autotune
Heavy Breather
Thunderheader
Evolution 30t sprocket set
C & C Seat
I love my bike..........but I miss my money.
bamofo666 is offline   Reply With Quote Quick reply to this message
Old 08-07-2010, 09:42 PM   #7 (permalink)
Pine Tree wants to know where he is and how he got here
Originally Posted by bamofo666 View Post
...Also, doesn't removing the sensor automatically change the AFR to 12.0-1 as stated below?
I think a more accurate statement might be that the system only "looks" for O2 sensor data when in closed loop. Removing the sensors might cause a code to be thrown, however.
..."During engine warm up the HD engine runs in open loop mode at a 12.0:1AFR. No matter what the engine temperature, this is the AFR that occurs at starting. If you disconnect the O2 sensors on the engine, this is the default idle AFR for the HD engine."
I don't think that's correct. The system does use other tables during startup.
...Also, my bike, no matter how hot, has never done this.
Does you bike have the EITMS? If so, is it "enabled" and is it turned on?
This is one of the reasons so many go to a tuner that's capable of allowing changes in the AFR as well as timing pretty much across the map which, in turn, helps with cooling and performance issues.
Pine Tree is offline   Reply With Quote Quick reply to this message
Old 08-07-2010, 11:15 PM   #8 (permalink)
your bike is in open loop any time its not in closed loop, and it doesnt live in closed loop like you think. but open loop is not 12:1, it is still a leaner mix, and remember--------thats on an unmolested bike! imagine opening the flow and you are lean in open loop probably moreso than closed loop. at least closed loop TRIES to compensate. resistors or other gizmos will/can keep the codes away so your light dont shine, and usually take the o2 out of the loop so it forces you to open loop-------where you hope its richer, but t the end of the day, your timing still sucks and your fuel still aint tuned.
