Pro PadLeslie Kay'sBikeBanditMotorcycle-CommunicationAmerican Side Road CycleMotorcycle.comJardineProducts.comJekillandHyde.eu
American Side Road Cycles
Old 11-04-2009, 12:22 AM   #1 (permalink)
powerlineman is on a distinguished road
ideas on thundermax map
I have been using thundermax with my build that has 1100 miles on it.
it is: 01 softail, 95" 10.5/1 weisco, baisley superstock heads, woods 7h cam, bc gerolamy 48mm reworked throttlebody, pro-pipe with 2 rows hose clamped.
Zippers told me to use the 475 map. It has a ping around 60% throttle at a decent roll on in 5 gear 60mph. I also have this surging problem at very light throttle at around 3500-4500 rpm in any gear. I am running one step colder plug also. It was 50 degrees here today and it still had pinging.
I am looking for ideas or suggestions. I dynoed this build and got 100/101 I feel there is more in it and hopefully I can get it to run better. I also get 37 mpg.
any ideas would be appreciated.... Just about to go back to a pc and get it dyno-tuned, but I figured I would give it another shot.
thanks, Powerlineman
powerlineman is offline   Reply With Quote
Old 11-04-2009, 08:58 AM   #2 (permalink)
Doof Toll Pimp
ktwillys's Avatar
ktwillys is on a distinguished road
sounds like your hp and tq are close to what you could expect.. Maybe a little more but not lots..
I found that the way that TMax chooses their maps for a particular build is not the best sometimes..
It didnt work for my build....
It has been a while since I figured out the sequence for picking a map... I will have to pull up the tmax page and see if I can remember the sequence...
but it made all the difference for my build..
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DC.....
04 FLTRI
SE Welded/Balanced Flywheel
103 Cubes
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
Thunder Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is online now   Reply With Quote
Old 11-04-2009, 08:47 PM   #3 (permalink)
Smile
thanks for the help, I don't mind the numbers that I got, the pinging and the surging is what really gets me. I has alot of power from 2500 all the way up though!
