Motorcycle-Communication
MBO EnterprisesMotorcycle.com Classifieds!Leslie Kay's
Diamond Bar Choppers
Motorcycle.com
Old 09-27-2009, 08:36 PM   #1 (permalink)
Slow Poke!
stacytmurphy's Avatar
stacytmurphy is on a distinguished road
TTS VE Problems
Why is the VE so much different between the front and rear.
The motor does not run no where nere as good as thought it would.
The following data is included.
VE GENERATED FILE
http://www.easy-share.com/1907931879/VERun6.pdf
117 MAP FILE
http://www.easy-share.com/1907931880/PJ176-002-B1-117 Motor-007.MT7
V-TUNE DATA FILE
http://www.easy-share.com/1907931881/VTuneData-122.DM3
_______________________________
2007 FLSTF
117, GMR Stage IV Heads
S&S 4.125 Cyl, CP Pistons, 10:84
Woods 9b-6, Stock Throttle Body(4.89 Inj)
TTS Tuner, Rinehart Exhaust
Renegade Wheels
To Much Chrome to list
stacytmurphy is offline   Reply With Quote
Old 09-27-2009, 09:50 PM   #2 (permalink)
Axe Man
BVBOB's Avatar
Very common to see front and rear VE's very different, mostly due to pipe configuration, couldn't get your files to open. What pipe are you running?
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
Old 09-27-2009, 10:34 PM   #3 (permalink)
2005 Road King Classic
bbrowncods's Avatar
bbrowncods is on a distinguished road
I posted a similar issue in the TTS Mastertune thread. If you look at the Vtune data Injector PW width they are close to being equal throughout the RPM range and throttle range. I am not sure how the ECU has such diverse VE values to get the same PW for the front and rear. They should be the same.
Other than just wanting to know why, what is important is that the AFR matches between front and rear and that the injectors are flowing the same amount of fuel between them at the same PW.
I still want to know why the math between the front VE and the rear is different.
05 Road King Classic - Sierra red pearl/Bassani Power Curve and Megaphones w/torque baffles/98" RevPerf BB/37g cam's/Stock 99B lifters/TTS/Stage 2 CNC'd heads by R&R(GMR) 9.7 CR/50mm Gerolamy Dual Throttle and filter/500cc injectors/Super Premium Oil Cooler/SE Clutch spring w/Easy-pull ramp and a bunch of this and that!
bbrowncods is offline   Reply With Quote
Old 10-23-2009, 12:48 PM   #4 (permalink)
bbrowncods's Avatar
UPDATE: I was unhappy that my VE tables were so different. I replaced my Gerolomy TB with my original TB and it ran worse. It was tuning but the rear cylinder was at half the VE of the front. Bottom line is I checked for intake and exhaust leaks and noticed a tiny little bit of soot along the slits between the rear cylinder pipe joint. Could that be it? I went to Advance and got a tube of exhaust leak "putty" (in a silver tube). I sealed that joint and the muffler joints as well.
Bingo! VE's are now about 1% of each other, and the bike runs strong.
stacytmurphy, you may want to look at your exhaust pipe joints for signs of leaking (soot).
Old 10-23-2009, 07:04 PM   #5 (permalink)
Slow Poke!
I have checked the pipes for cracks, and made sure the gaskets are not leaking.
2007 FLSTF
Renegade Wheels
Old 11-06-2009, 09:14 AM   #6 (permalink)
The Student is on a distinguished road
The rear cyl. VE's are reflective of an exhaust leak in the rear cyl...where it is...you'll have to find it...You may also want to check that your CID is correct in the tuning constants..
The Student is offline   Reply With Quote
