RRcycles.comMotorcycle.com Classifieds!JardineProducts.comCycleGear.comCustom DynamicsPro PadMotorcycle-Communication
Leslie Kay'sMotorcycle.com
Old 09-16-2009, 12:49 AM   #1 (permalink)
Steve H's Avatar
Steve H is on a distinguished road
do I need the Fuel Pak
HI all,
I recently put on V&H classic slip on's with the Fuel Pak, and stage one kit (Arlen Ness big sucker) on my 09 FLHT........I love how responsive it is....my question is this......my wife has an 08 Nightrain, and her son and I put V&H short shots on it for her......can I just do the stage one to get a better air fuel mix, or do I need the fuel pak? her bike runs good now, and since I am new to this, I don't want to damage her bike, and want to know if it would be ok to do the stage one first then the fuel pak in a few months.....
thanks guys....
Steve
Steve H is offline   Reply With Quote
Old 09-16-2009, 05:29 PM   #2 (permalink)
squale147's Avatar
squale147 is on a distinguished road
are you talking about getting the stage 1 down load from h-d??? if so theres no need to do that if your getting the fuel pack.. you should get some kind of fuel prosseser.. t.b.h i would get a pc3 or pcv.. those units have alot more adjustablity.. i hope this helps
motocross#147 drag racing#4933
squale147 is offline   Reply With Quote
Old 09-17-2009, 12:46 AM   #3 (permalink)
Steve H's Avatar
I have the Fuel Pak on my bike, and are very happy with it, being that the funds are tight, I wanted to know if it would be better to get the larger air cleaner (I have the Arlen Ness big sucker on mine), first, then get the Fuel Pak a bit later........
Old 09-17-2009, 06:03 PM   #4 (permalink)
squale147's Avatar
you should wait till funds are good and then do bolth at the same time..if you do the big sucker with out the fuel pak the bike would really be running lean..
Old 09-19-2009, 01:14 AM   #5 (permalink)
Steve H's Avatar
thanks for the note....will do......her bike seems to run fine now....but after doing all to mine (pipes, FP and air kit), I want hers to run as efficient.....
Old 10-25-2009, 06:44 AM   #6 (permalink)
Fuelpak
Originally Posted by Steve H View Post
HI all,
thanks guys....
Steve
Your thinking is fine, won't hurt anything. The stage 1 down load doesn't do much for fuel. The Fulepak will make it run cooler as their all so lean from factory because of EPA standards.. Good Luck
Old 11-06-2009, 09:31 AM   #7 (permalink)
The Student is on a distinguished road
Steve H...Before you pull the trigger on the fuel pak...Be aware that your 08 and 09 bikes have some great technology that you can utilize to get the best runnability out of your bike and IMHO the fuel pak would not be the way to go...TTS Mastertune is, again IMHO, probably a better choice. I have seen some very poorly running bikes using the Fuel Pak and have had nothing but good response with TTS's product. The ability to use a tuning devise that actually modifies the tables within your ECM, rather than adding the Fuel Pak module(another possible failure point), is priceless. The fuel pak is a signal modifier that takes the stock signals from the ECM and modifies them to give you more or less fuel as needed... The Mastertune allows you to modify all of the neccessary tables in the ECM to get your bike EXACTLY where it needs to be based on YOUR engine's needs...It will be neccessary to optimize the VE tables for the best runnability of your mill and that simply cannot be done with a fuel pak. It is in your best interest to use a tuning devise that actually works WITH the adaptive learning that your bikes have, rather than against it...
Just an opinion...hope it helps
The Student is offline   Reply With Quote
Old 11-08-2009, 07:23 AM   #8 (permalink)
FuelPak
Student; FuelPak is relyable, works very well, can't say how it compares to others but it's a good unit to buy.. I don't have stock in V & H's.. I read a thread about Fuelpak, it's here on this site. I'll try and find..
Old 11-09-2009, 07:44 AM   #9 (permalink)
GOOD LUCK!!
Old 11-09-2009, 08:23 AM   #10 (permalink)
strokerjlk's Avatar
good advice
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
strokerjlk is online now   Reply With Quote
Old 11-09-2009, 02:25 PM   #11 (permalink)
brwk's Avatar
brwk
Out of all the things out there I believe the TTS is the best so far.
brwk is offline   Reply With Quote
Old 11-09-2009, 02:38 PM   #12 (permalink)
Are we having FUN yet?
Jeffytune's Avatar
The short answer....
YES
Ok, a bit longer answer, weather a Fuelpak or other device should be used anytime you increase airflow through the engine.
I see no upside to having the "Stage one" download installed, as there are programs in for the Fuelpak for with or without.
Seems like a waist of 150.00 dollars to me.
I'm Just Sayin'...
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
92.85 Torque 80.08 HP
Professional Rockat Surgen
Disclaimer.
Old 11-09-2009, 03:17 PM   #13 (permalink)
FLTRI is on a distinguished road
Enricheners
And my opinion as well based on the number of enricheners we've removed and replaced with PCs/SERTs/SESTs/and Matertunes to properly tune fuel AND timing for changes.
From our experiences the enricheners work OK for stage 1 bikes but that is where it ends. Once cams and/or heads, or V&H pipes have been changed the engine needs to have fuel lessened in places as well as enrichened in others.
The enricheners will make the engine run cooler simply because they use more fuel to cool the combustion which, in turn, usually loweres power in places where added fuel wasn't needed. Usually timing changes will make better differences than simply adding fuel, and in some areas where added fuel is not required/wanted.
Bob
FLTRI is offline   Reply With Quote
