Low fuel level causes slow idle
My '05 fuel injected Electra Glide has developed an annoying new habit. When the fuel tank gets down to 1.5 gallons or so, the idle drops from about a thousand on the tach, to 800. Sometimes it will slow enough to die at a stoplight. This only happens when the fuel level in the tank is low. At 41,000 miles, I'm past the recomended replacement mileage for the fuel filter, and I recall some discussion about the hose inside the tank developing holes that cause problems. Since the gasket and sealing screws for the canopy cover are kind of pricey, I figured I would replace the fuel filter and hose to the fuel pump at the same time. Should I also replace the fuel regulator? Any other thoughts on what could be causing the low idle when the fuel level is low?
Onward, into the fog!
