Anyone know how to best tweak a PC-III map?
For elevation or to change the base A/F ratio?
I had a friend tune my PC-III USB on his dyno at sea level. He set the entire range at 13.8. I live at almost 6,000' elevation and I'd like to lean it out just a bit more. The cell numbers on the fuel map are all over the board, but I was looking over his shoulder as he tuned so I know that the A/F ratio is constant throughout the range. Would I want to reduce ALL numbers by a percentage, or just by a set amount? In other words, if four cells have 20, 40, 60, and 80, would I want to reduce them all by the same amount and change them to 15, 35, 55, and 75, or reduce them all by the same percentage and change them to 15, 30, 45, and 60 to maintain the same levels of change?
Also, does anyone know just what A/F ratio I can expect at a given elevation if I know the A/F ratio at sea level?
Thanks,
Tom.
