GoFreeCreditReport
Old 08-18-2009, 09:32 AM   #1 (permalink)
Colorado crusin'
NewHawk's Avatar
NewHawk is on a distinguished road
Starving for fuel? 07FXDWG
I have recently developed a problem. Cruising around in town or on the highway the bike suddenly feels like it is running out of fuel, will backfire and the engine will catch again. Sometimes it will do this 3 or 4 times in a row (starve/backfire/catch). It just started last week.
It feels like a fuel problem not a lack of ignition.
Any suggestions on where to look?
I have tried a couple things but would like to hear all suggestions.
TIA
07 FXDWG
SE A/C, K&N filter
Andrews 26h, D & D FatCat w/QB
True-Track
NewHawk is offline   Reply With Quote
Old 08-18-2009, 08:35 PM   #2 (permalink)
Colorado crusin'
NewHawk's Avatar
Bump
Intake manifold leak?
07 FXDWG
SE A/C, K&N filter
True-Track
Old 08-18-2009, 09:39 PM   #3 (permalink)
Axe Man
BVBOB's Avatar
Check your injector wires at the plug, you may be dropping a cylinder at times.
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
Old 08-21-2009, 06:39 PM   #4 (permalink)
HDWRENCH's Avatar
What tuner do you have?? I see the engine mods and there is no canned map that is going to work well with that.
GMR PERFORMANCE
928-445-3473
TTS TUNING CENTER AND SALES
WWW.GMRPERFORMANCE.COM
Old 08-21-2009, 06:49 PM   #5 (permalink)
Altered States
Waffen's Avatar
Waffen is on a distinguished road
I had a similar problem in Sturgis couple of weeks ago. Same symptoms. I stopped a a gas station on Iron Mountain filled up waited for an accident to be cleared up then took off. Sputtering, coughing, backfiring you name it. It turned out to be some nasty sediment in the gas. I did not notice the very small refueling truck filling the gas holes while we were filling up. I drained the gas, cleaned out the carb, and crossover tube between the tanks and off I went..
Don't know if this could be your problem but crap in the gas sure caused me similar issues.
W
Marx and Anliski did not sign the Declaration of Independence!
Waffen is online now   Reply With Quote
Old 08-22-2009, 08:13 AM   #6 (permalink)
Colorado crusin'
NewHawk's Avatar
It was tuned using a direct link. Tune is great, 16k on the tune.
I have drained the gas tank. I did find a code PO373 (intermittent CKP sensor) and replaced the sensor, bike still acting up.
07 FXDWG
SE A/C, K&N filter
True-Track
Old 08-22-2009, 08:53 AM   #7 (permalink)
rear injector wire is notorious for breaking inside the plastic.
Old 08-26-2009, 09:41 PM   #8 (permalink)
Colorado crusin'
NewHawk's Avatar
Replaced pins on connector just for the heck of it. Started bike, seemed to run fine. Dropped it off the lift and it ran worse than before. I tried so many things and when I would drop it off the lift it would run like crap on a run around the block. Finally had it towed to Harley dealer yesterday afternoon after getting 2 CPK faults (I had already replaced the crank position sensor).
One thing I failed to notice in all my attempts is that the bike ran fine on the "frame" lift I was using but when I set it on the ground it would soon begin running like crap.
At the dealer's they used a "table" lift and quickly traced the problem to a fault in the main harness between the CPK sensor and the ECM.
I'm guessing that when on my lift with the rear wheel/swing arm hanging down the fault wasn't faulting.
ANYHOO I got the bike back and will run a tank of gas driving around town making sure it works before anything long distance.
Thanks for the suggestions guys.
07 FXDWG
SE A/C, K&N filter
True-Track
