CycleGear.comAdvanstarMotorcycleShowsMotorcycle.comSportbikeTrackGearBub EnterprisesPro PadMBO Enterprises
Old 08-08-2009, 03:21 AM   #1 (permalink)
crusty369 is on a distinguished road
Angry TMAT computer problems, HELP!!!!
UPDATE!!!!!!!!!!!!!!!BAD SERIAL PORT CABLE!!!!!!!!!! The serial cable has a comp. chip in it. Apparently it was toast. Working like a champ now. Buy a spare!!!!!
Okay, let me begin by saying I am like kryptonite to computers. That being said, here's my dilemma:
Bought A thundermax w/Auto Tune feo
a member on this forum last week, installed it on my WG, and went about getting it up and going. Problem right out of the gate, no serial to USB adapter. Weekend, so I went to Radioshack and bought one. Big mistake. Laptop number one would not allow the port to work properly. Finally got it to work with my other laptop. Installed the closest map per instructions, and the bike is running great. Unfortunately, I tried to connect again, and when I go to link, NO Module found, blah blah. Laptop shuts down. Called zippers this week, and was told that the adapter I bought was too fancy, and that It was causing a conflict. Bought the generic feo
them, same problem.
I have uninstalled/reinstalled smartlinkiv, and it still doesn't help. Unfortunately, both my laptops run Vista Home Premium. Crap OS, I know.
Getting numerous errors on both laptops rating to corruption in feature manager/backup file loaded, a d unknown software error. Both laptops worked fine before the Thundermax debacle. I even tried to go back to a restore point from a couple of weeks ago on one of the laptops, and I get a failure message. Totally confused. Frustrated, and pissed.
Any guidance would be greatly appreciated. Heads go on, a d cams go in on Wednesday. I need thus thing to be up and going, and at this point I am totally stumped.
Shawn
a couple of weeks ago, and
2006 FXWGI, SE 95 BB kit, (2005) Ported heads, Wood TW6-6 Knight Prowler cams w/+4 gear, D&D Fatcat SB, TMAT, Thunderheart speedo, Doherty PowerPacc w/Power Vents, LePera Silhouette 2 up, HD 3" fat risers, Arnott adjustable air-ride with on-board Compressor (9.5-12.0in), RWD Maltese Cross Billet headlight, 3 degree tree cups, Billet re-usable oil filter with 35 micron surgical steel screen, Kuryakyn +3" fwd control extension kit, 2" tank lift......
Last edited by crusty369 : 08-22-2009 at 05:10 PM. Reason: Problem solved, bad cable.
crusty369 is offline   Reply With Quote
Old 08-08-2009, 07:28 AM   #2 (permalink)
Eleft36's Avatar
Eleft36 is on a distinguished road
them, same problem.
Shawn
Up grade to vista premium, then do the Microsoft update.
Al
V&H Slip Ons W/Double quiet baffles Stock A/C Stock Heads Stock Cams Mustang Wide Touring Seat Stock Bars H.D. Oil Cooler Fat Boy Bags H-D Windshield Thunder Max A/T
SE Compensator Kit
Eleft36 is offline   Reply With Quote
Old 08-08-2009, 08:36 AM   #3 (permalink)
not compatible with hypercharger!
man, make your lptop dual boot. load windows xp on a different partition and use it to run t-max and other stuff. use vista for everyday stuff. i have found tripp-lite serial to usb adapters to work flwlessly, YMMV. of course, buying a used laptop with serial port would be best bet for around $150.
Old 08-08-2009, 11:12 AM   #4 (permalink)
Doof Toll Pimp
ktwillys's Avatar
ktwillys is on a distinguished road
I have the radio shack usb adaptor and have no issues at all.. it works great..
I also am running windows XP not vista.. I wont even try to attach my vista based computer to my Tmax...
because of all the problems you are having..
it sounds like your computers are having the problem not the tmax..
if you can try running on a xp system..
hope it works for you..
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DC.....
04 FLTRI
SE Welded/Balanced Flywheel
103 Cubes
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
Thunder Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is online now   Reply With Quote
Old 08-08-2009, 09:40 PM   #5 (permalink)
Eleft36's Avatar
My laptop with vista premium updated works fine with my Tmax.
I have no problems.
Al
SE Compensator Kit
Old 08-09-2009, 03:08 PM   #6 (permalink)
Rey
Rey
Try this site for the R-S adapter driver, it's near the bottom of the page.
http://www.floridaprobe.com/usb_install.htm
Rey is online now   Reply With Quote
Old 08-09-2009, 09:07 PM   #7 (permalink)
atrick is on a distinguished road
I had problems with vista and t-max but also had problems with other programs with vista, running xp now and works great with the radio shack cable. If you run a dual boot system you need to have two separte partitions on your hard drive to make it work. Or do what claydbal said buy cheap laptop just for this purpose only!
07 FXDWG
D & D Slipons
Redshift 575 cam
SE adjustable pushrods
K & N air cleaner
T-Max w/auto tune
Race Tech progressive wound fork springs & emulators
78 SuperGlide
Andrews B Grind w/solids
S & S Super
Dual Pipes
atrick is offline   Reply With Quote
Old 08-10-2009, 12:18 AM   #8 (permalink)
Coolmaker's Avatar
I have Vista Home on my laptop and it runs flawlessly with T-Max. Make sure you have the right drivers installed.
06FLHRCI
Old 08-10-2009, 05:52 PM   #9 (permalink)
keener's Avatar
keener is on a distinguished road
I agree with coolmaker.
They are selling these little mini laptops for cuising the web, with a small hard drive. I am thinking about getting one (about $189) for the TMAX, and while at hotels on the road. May be just what the doctor ordered. Small size, small price, fits my needs...
'05 Ultra
95"BB - Heads by Boar House...TMax w/AT...HQ0034g...VH 2:1...VPC
keener is offline   Reply With Quote
Old 08-10-2009, 07:26 PM   #10 (permalink)
let us know how that works out. have wondered how they would be for carrying in a backpak and datalogging. saw one for $49 if you had a 2 year contract on cell phone internet---which wouldnt be a bad thing in some areas. not here-----they still think 750k dsl is broadband.
Old 08-10-2009, 08:52 PM   #11 (permalink)
Eleft36's Avatar
Mine fits in the small fat boy saddle bag, set it to stay on when closed and run the monitor logging feature.
Replay it and make adjustments from the monitor real time replay.
Al
SE Compensator Kit
Old 08-22-2009, 05:11 PM   #12 (permalink)
Problem solved. See top. Thanks for the advice. ......
