T-Max rear cylinder misfire advice?
OK here is the bike details.
2003 roadking
88inch
SE 204 cams
Zipper breather
Rhineheart true duals
t-max with auto tune
bike idles rough and slow rpms runs rough. heavy throttle seems ok but is lacking performance. While idling, if cover front exhaust, sounds good. cover front and sounds rough.
Looked at specs in tmax after run down road for a few miles and it shows the front cylinder kinda smooth but changed. the rear cylinder is all over the place. Been troubleshooting for a few days now. changed intake manifold gaskets and tested. no leaks. switched O2 sensors and no change. switched spark plugs, no change. switched spark plug cables, no change. changed exhaust baffles, no change, put smaller air cleaner back on, no change.
If the bike is sitting here, and i raise it up to 2200 rpms you can here that the rear cylinder is popping and not smooth like the front is. I emailed t-max the programs stuff but most of them are at sturgis so i wont get help from there till they get back. I need advice please.
