07-28-2009, 09:35 AM
Well it's here...Lambda based Fuel Tables
Yes the new DBW touring bikes for 2010 will be replacing the AFR tables with Lambda based fuel tables. The new calibrations will be a 218 level.
The VE tables will be calibrated in MAP (kPa) not throttle positions any more...this I find very interesting.
You TTS owners....update your software and you can read all about the tuning changes with the Lambda based tables in the Tuning Guide...I'm sure you will find this very interesting.
The auto industry has been using this Lambda system for years and it will be more accurate fueling for the Harley also, but, it is a bit awkward getting your head wrapped around a whole different way of looking at fuel values....no more AFR. Example; Stoitch with AFR values is 14.68, this is something we are used to looking at however stoitch in Lambda is 1.000. Any value higher than 1.000 is leaner than stoitch and any value lower than 1.000 is richer.
With this new system we will be able to get a more controlled Closed Loop area (the bias voltage tables will be gone) To V-Tune your bike the fuel table will be set at .981 not 14.6 any more. The value of .981 equals 14.4 afr.
While in closed loop you can set less loaded cells with a leaner value and the loaded cells with a richer value....its really cool. The Lambda values will range from 1.020=14.97 to .967=14.20 in closed loop (I think) and to much richer values in open loop.
So you ask why the change...and that is a good question. With todays fuels (E10 and E85) stoitch changes....ie... the stoitch for gas as we know it is 14.68 however when using corn gas it takes more volume of fuel to produce the same amount of energy that gas does so E85 stoitch rating is 14.28. Here is where Lambda based values come in.....no matter what the fuel is stoitch is 1.000 = 14.68 for gas and 1.000 = 14.28 for corn gas. I believe we will be able to select a blend of fuel....Blend A or Blend B and not have to retune for these different volumes.
There is a lot to this Lambda stuff and knowing it was coming I did some research on it through the net last year so I'm ready....how about you guys? .....get to reading....lol
Doc
07-28-2009, 09:54 AM
Doc
Yeah....no issues here. What's it going to mean for the AFR tuning guys?
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
07-28-2009, 11:32 AM
mooooving out!
What about those of us that have 04 and earlier? will this effect us?
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
07-28-2009, 02:52 PM
No Paul, only the new DBW 2010 touring bikes, the 09 touring bikes have the option of 205 or 218 calibration levels. The 218 cals are the Lambda based Values.
Doc
07-28-2009, 03:22 PM
so for my 07 this means nothing?
07 FLHTC 117, Wood tw8 cam,55 HP TB,HQ heads,D&D Fatcat,SE4.9 injectors,SERT
07-28-2009, 05:37 PM
That is correct...this means nothing for any bikes older than 2010 touring models.
07-28-2009, 05:45 PM
0043--Licensed to Doof!
What about us with carbuerators???
I Doof, therefore I am.
D.F.F.D
07-28-2009, 06:14 PM
....and notice the location of the O2 (lambda)sensors........I just looked at a RG, both sensors...side by side...at the collector.
07-29-2009, 07:57 AM
2005 Road King Classic
What are the axis' for the Lambda tables? (I assume RPM, and either throttle or MAP)
Do the new O2 sensors operate as wideband or narrow? If the Lambda tables go across the the whole operating range of the engine it would seem to me that they would need to be able to read as wideband. But they may still be like the earlier models and just be mapped when outside the narrow range around stoichiometric.
05 Road King Classic - Sierra red pearl/Bassani Power Curve and Megaphones w/torque baffles/98" RevPerf BB/37g cam's/Stock 99B lifters/TTS/Stage 2 CNC'd heads by R&R(GMR) 9.7 CR/50mm Gerolamy Dual Throttle and filter/500cc injectors/Super Premium Oil Cooler/SE Clutch spring w/Easy-pull ramp and a bunch of this and that!
07-29-2009, 11:33 AM
There is no need for a wide band 02 sensor in a Harley...matter of fact they are too slow compared to a narrow band switching device.
The ECM does not read AFR or Lambda it reads voltages...the wide band sensor does not put out a voltage that the Delphi can interpert.
I made a thread in this section on the new Mini 02 sensors....check it out
07-29-2009, 05:20 PM
Lambda
Doc
Hey, I updated the software but cannot seem to find any 218 level cals.Is it because they are not out yet?
Paul
07-29-2009, 05:55 PM
Paul
They will be out in a week or two at the latest, they will be on the updater when they are ready.
Doc
08-01-2009, 06:49 PM
Doc
So, am I right in assuming that these Lamda maps will apply to the 09 street glide. I just want to make sure.
paul
08-01-2009, 08:27 PM
paul
The 09 Lambda calibrations will be a 218 file, the 2010 Lambda calibrations will be a level 009 file.
Doc
08-01-2009, 09:11 PM
Doc
Thanks doc. I'm looking forward to playing with these. It seems to make alot more sense in the aspect of basing calculations on the actual (or closer anyway) stoich given the fuels we are using.
paul
