SportbikeTrackGearCycleGear.comDan Vance RacingPro PadMBO EnterprisesBikeBanditBub EnterprisesMotorcycle-CommunicationDiamond Bar Choppers
JekillandHyde.eu
American Side Road Cycles
Old 07-18-2009, 05:48 AM   #1 (permalink)
Goat
Screaming Eagle Race Fueler Help
I know this has been discussed before and I do remember someone listing the correct set-up procedures ... however I cant find them here ... has anyone seen the full set-up and can you post it here for me ... Goat
Goat is offline   Reply With Quote
Old 07-18-2009, 08:24 AM   #2 (permalink)
JohnC is on a distinguished road
Compiled from notes I've collected:
Introduction
NOTE: Counterclockwise is off (7 o'clock) on all the fuel adjustment pots and the lowest RPM point on the RPM adjustments. There are three lights on the unit and each light shows what range you are in so you can adjust the correct fuel adjustment pot. You want the least amount of clockwise rotation to make the engine run smooth for your combination. Also, some owners have reported their race fueler units to have the LEDs mounted in a GREEN | YELLOW | RED sequence whiles others had the LEDs in a RED | YELLOW | GREEN sequence. This seems to vary based on model year bike and application. However, the same general adjustment instructions apply.
Adjusting the RPM pots
The easiest way to setup the RF is start the bike and warm to normal engine temperature. Hold the RF with the adjustments on the right so you have one row away from you at the top of the RF and the other row close to you near the bottom. In this view the lower left adjustment is the low to mid RPM set point. I start by setting this at 1800 RPM. If you have a tach just hold the motor to 1800 then adjust the pot until the light switches from the middle light (YELLOW) to the one furthest to the left (GREEN). Once you've done that move over one pot to the right. This is the mid-to-high RPM adjustment. I set that to 4500 RPM to start. Do the same as before only the light will switch from the far right light (RED) to the middle light (YELLOW).
Adjusting the fuel mixture
Rev Engine to 1700 RPM and adjust the top left POT clockwise for the smoothest possible engine (or stops gaining RPM). Only the left LED (GREEN) should be on. Once you have done the adjustment, start to go counterclockwise until the motor begins to slow just a little and stop there. Be careful to watch the light as only the far left light (GREEN) should be on while adjusting. If it switches to the middle light (YELLOW) you will need to back off on the throttle some. Once you have done the adjustment, start to go counterclockwise until the motor begins to slow just a little and stop there. Now raise the RPM to 4000 and the middle light should be on (YELLOW). Follow the same adjustment procedure on the mid fuel adjustment pot. It is the middle pot on the top row. I leave the high RPM fuel adjustment off to start with (counterclockwise all the way).
Adjust the accelerator pump setting
Now move to the lower row far right pot; This is the accelerator pump adjustment. Give the engine a good quick throttle snap, paying attention to how it revs up. If it revs quick and clean do nothing. If it pops back or stumbles turn the pot clockwise 1/4 turn and try again. If that fixes it adjust the pot down (counterclockwise) until the pop/stumble comes back. Then go clockwise just a little to get rid of the pop/stumble. You want the least amount of accelerator pump you can without a stumble. Take it for a ride and see how it runs. What you want is the fuel pots to be as far counterclockwise as you can with a good clean running bike.
The high rpm is the hardest to adjust because you need high engine speed to tell. It adjust the same as the others but it doesn't adjust well at no load. So just go ride hard and at high RPM and try adding some fuel, if it gets better try a little more. You want to add the least amount to achieve a smooth running bike.
JohnC is offline   Reply With Quote
