Leslie Kay'sCustom DynamicsBikeBanditFuel MotoDiamond Bar ChoppersMotorcycle.com Classifieds!Original Bike SpiritsSportbikeTrackGearPowerstar Sparkplugs
Old 01-24-2009, 12:35 PM   #1 (permalink)
dustyroadking is on a distinguished road
Unhappy T Maxx Tunner
Let me start by saying its been some time since I was here and think I need to spend more time here
I am looking to get my T-Max set up right.
The power plant is an 04 twincam - Mods are, R&R 525 gear drive cams,Flowed heads and bored to 98 CI
rinehart true duals. I have about 8000 miles on the rebuild,the bike runs strong and getting around
43 mpg across the board. even with the bike loaded it will not loose speed on the hills but when its
hot like a good romp down the highway hot it wants to ping if I give it some throttle. I can down shift
and get past it but I need to know which way I need to tune to get the ping out. I have replaced the
comp releases due to carbon fouling. (Help) As of now I am on a super restricted Buget due to the
current state of our ecconomy.
dustyroadking is offline   Reply With Quote
Old 01-25-2009, 09:35 AM   #2 (permalink)
Just another Hog Jocky
mtnmotorrider's Avatar
mtnmotorrider is an unknown quantity at this point
Use the graduated numbers tape on the throttle grip method described in the tuning manual to find at what rpm and thottle position you are experiencing ping. Go to the map or maps in the timing vs. thottle position tuning tree that you identified and start taking timing out a little at a time. Be sure to smooth the changes in with the rest of the curve if it is more than a degree or two. Test ride and make additional changes as dictated. You can't hurt anything and you can always go back to square one on the maps, as they will still show the original curves after you make the changes.
My friends like me; everyone else thinks I'm an asshole. What's that say about my friends?
'07 Road Glide, 103 ci, Big Boyz "Bigger Valve" Street Port 85 cc heads, .030 quench for 10.2:1 cr, SE flat tops, Wood TW 6-6's, K&N air filter, Cobra/Fat Cat bastardized two-into-one exhaust, TMAT ECM with Auto-Tune.
mtnmotorrider is offline   Reply With Quote
Old 01-25-2009, 03:57 PM   #3 (permalink)
Sleeps In Trees is on a distinguished road
I have replaced the comp releases due to carbon fouling.
Good advice above, but it sounds like maybe carbon build-up could be part of your trouble. Has it pinged since it was built? Maybe some water mist thru the TB could help...worth a try & the cost is right.
VicW.
'02 Ultraglide:
SE 1550 Cast FT Pistons
'06 Deweys 'Pro Street' heads
Andrews 54N Camset
Doherty PowerPac W/Vents
Zippers Filter Conversion
D & D Fatcat Exhaust
Energy One Clutchpak
SE Clutch Spring
83T VPC
3.37 Gearing
TTS
Sleeps In Trees is offline   Reply With Quote
Old 01-25-2009, 03:58 PM   #4 (permalink)
Are your breathers routed to the intake?
VicW.
'02 Ultraglide:
Andrews 54N Camset
SE Clutch Spring
83T VPC
3.37 Gearing
TTS
Old 01-25-2009, 05:15 PM   #5 (permalink)
sleeps in trees hit it i think. the true duals allow the fresh air reversion to corupt the o2 sensors, they tell the ecm the motor is lean and it slowly riches the mix. do the water thing, once decarboned, reset all learned offsets, allow about 300 miles of tuning (different throttle positions and turn off motor and restart often. once engine feels like it runs well, turn off the autotune and remove autotune module and plug o2 bungs.
Old 01-25-2009, 06:09 PM   #6 (permalink)
todd comer is on a distinguished road
Great advice Dennis!! Throttle response and every aspect of my engine is so much better since I shut off the closed loop function on my DTT.Bike had been running the closed loop for over a year therefore felt that it had been tuned enough.Never thought clicking the closed loop feature off would have improved the rideability like it did.My 98" would ping some with the DTT timing table but retarding certain rpm's fixed that.
todd comer is offline   Reply With Quote
Old 01-29-2009, 09:00 AM   #7 (permalink)
Sounds like good advice and will get Started today ---- I do have one more question- If I were to take the laptop with me and do a run while it is hooked up to the tunner would that show where the problem is and get me closer to the info I need to make the changes? Again thanks for the input. Looks like a good day for a ride
Old 01-29-2009, 06:17 PM   #8 (permalink)
remember, you can chase your tail that way. collected data is only as good as the signal. have you had the timing tables tuned on a dyno? have you compared your o2 readings to a dyno probe? only then can you use collective data.
