Pro PadBub EnterprisesAdvanstarMotorcycleShowsBikeBanditFuel MotoMotorcycle-CommunicationDiamond Bar Choppers
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Performance Forums > Dyno Discussion
Pro Pad
Old 10-23-2009, 06:06 PM   #1 (permalink)
Slow Poke!
stacytmurphy's Avatar
stacytmurphy is on a distinguished road
117", RR Stage 4 heads, Woods 9b-6
Build is in sig. TQ/HP very low.
_______________________________
2007 FLSTF
117, GMR Stage IV Heads
S&S 4.125 Cyl, CP Pistons, 10:84
Woods 9b-6, Stock Throttle Body(4.89 Inj)
TTS Tuner, Rinehart Exhaust
Renegade Wheels
To Much Chrome to list
stacytmurphy is offline   Reply With Quote
Old 10-23-2009, 06:32 PM   #2 (permalink)
Moneygreen
arealinvestor is on a distinguished road
Something seems wrong there!!! Sorry,but i wouldn't be pleased with that build!!!
Craig G.
Old 10-23-2009, 07:23 PM   #3 (permalink)
mooooving out!
route66paul's Avatar
have you done a compression check? do you know what the static comp should be?
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 10-23-2009, 07:24 PM   #4 (permalink)
Axe Man
BVBOB's Avatar
Throttle body and pipes are the limiting factors IMHO, your out of air by 3500 rpm. Your pdf file says Dyna but your sig line shows a softail, which is it? Also notice runfile 4
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
Old 10-23-2009, 07:33 PM   #5 (permalink)
who did the tune? reference phat117 as he has 2-2 and near stock TB. but great heads, great tune, great graph, great builder, yada, yada.
Old 10-23-2009, 07:49 PM   #6 (permalink)
baggersport's Avatar
baggersport is on a distinguished road
....and a different Dyno....? You may have some limiters as BVB mentions, but don't chase someone elses numbers.
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
baggersport is offline   Reply With Quote
Old 10-23-2009, 07:54 PM   #7 (permalink)
Slow Poke!
File should say 117Dyno.
I have a HPI 55mm I'm installing this weekend, hopfully it will help some.
I still have not decided on the pipe for the build.
I had a base run done to see if it was running to rich/lean, and were the HP/TQ would fall.
The Tune to come after TB, pipe install and finish breaking in the motor.
2007 FLSTF
Renegade Wheels
Old 10-23-2009, 09:27 PM   #8 (permalink)
Here for the education!
hdryder is on a distinguished road
Why was the bike on the dyno? You stated its not broke in yet and based on the fact I dont see and air fuel line(maybe you just didnt print it?) you didnt have it on there to verify a/f ratio for breakin. It really has no business being on there if these steps were not going to be taken. I have seen many build come in with figures like that and after a tune come away shining like a star. Dont jump the gun yet.
hdryder is offline   Reply With Quote
Old 10-23-2009, 10:28 PM   #9 (permalink)
Average Dude
YankeeBob's Avatar
Stock tb...questionable pipes...improper tune....What did you expect??? Really!!
Look how the tq drops off after 3500. Your engine ran out of breath!
Too soon to start barking. You need to finish things up first. Get a break in tune loaded, break it in and then get your final tune dialed in, then come show off your build.
Deut. 23:12-13
Old 10-24-2009, 01:50 AM   #10 (permalink)
towboattrash34 is on a distinguished road
The TTS is a good unit it is not perfect.... tuning a 117 while trying to ride is not fun and you can't get it right..... i tried...... just wait till you have it broke in the get a Dyno tune on it.....not a riding around town tune..... if i would of known how hard it was to get right i would of just kept my sert
Broke Down Money Pit....
towboattrash34 is offline   Reply With Quote
Old 10-24-2009, 07:43 AM   #11 (permalink)
Iron Will
Hillside's Avatar
Jeff,
What t/body, and pipe combo did you have, on your 117" prior to the disaster??
Scott
Old 10-24-2009, 07:49 AM   #12 (permalink)
Iron Will
Hillside's Avatar
Not only is the t/body size(and proper injector size) and exhaust(if over exhausted there will be a dip, and if under, there will be a nose dive around 5000, usually) of importance for the ablity to produce, but the I.D. of the port, as well as the I.D of the manifold, and the valve(s) sizes, and port shape as well.
Scott
Old 10-24-2009, 08:37 AM   #13 (permalink)
ryanl's Avatar
ryanl is on a distinguished road
yes they are. even with the components your running, with a good tune I would think you would be putting out a good bit more. Regardless of what dyno it was run on. BTW, who did your heads? Thread title says R&R, sig says GMR.
Hillside 98" Small Bore Kit
Stage III Heads
Stock Throttle Body Bored to 46.5mm
Hillside Air Filter
Woods TW-6G cams
S&S Adjustable Pushrods
D&D Fatcat (standard baffle)
Barnett Clutch Spring
ryanl is offline   Reply With Quote
Old 10-24-2009, 10:10 AM   #14 (permalink)
midnight sporty's Avatar
midnight sporty is on a distinguished road
shouldent a 117 run upwards of 138 to 145 hp and tq? its time for a hpi 55 or 58 and a borzilla
08 crossbones
hillside 107
woods tw8 cams
hillside stage 3 heads
s&s roller rockers
s&s adj pushrods
55 hpi throttle body
larger injectors
D&D fatcat-perf baffle
vp92t
hillside air filter
230 ccp
not one ounce of pinging
hillside cycle...
midnight sporty is offline   Reply With Quote
Old 10-26-2009, 07:11 PM   #15 (permalink)
Who would've let you get away with a stock tb on that build??? a bigger throttle body and different exhaust are for sure, IMO. A good exhaust is SO cruicial in tying a build together. I had a guy come to me and want his 124 tuned with a custom 2-1 pipe on it that was hand built by a racecar outfit from a near by town. This pipe was beautiful and a work of art, there's NO way I could build a pipe that nice. But the bike didn't tune for $hit and made 109hp/128tq. He thought it was fun to ride til I sold him on a Boarzilla and it picked up 30+ hp and 15 tq. You're not going to run a marathon breathing through a straw.
