Something you all should know about Dynos : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Dyno Discussion > Dyno Archive
Old 12-11-2012, 04:05 PM   #1 (permalink)
S&S Cycle's Avatar
S&S Cycle wants to know Dino or Syn?
Lightbulb Something you all should know about Dynos
Make sure you look at the Correction factor on "Claimed" HP/TQ numbers on Dyno charts. There are two different correction factors used for correcting altitude and air temp when doing dyno runs.
In the upper right hand corner you will see "STD" or "SAE" which are the two most common. When comparing numbers these need to be the same. STD will read about 4% higher than SAE because of the correction
SAE: "SAE (Society of Automotive Engineers), USA. Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25C). This SAE standard requires a correction for friction torque.
STD is Another power correction standard determined by the SAE. Power is corrected to reference conditions of 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5C). Because the reference conditions include higher pressure and cooler air than the SAE standard, these corrected power numbers will always be about 4 % higher than the SAE power numbers. Friction torque is handled in the same way as in the SAE standard."
If two dyno charts do not have the same correction factor, then you are comparing apples to oranges!!!
Thanks if you have questions just ask!
S&S Cycle, Inc. Performance American made Motorcycle Parts for American V-Twins since 1958
S&S Cycle is offline   Quick reply to this message
Old 12-12-2012, 05:37 AM   #2 (permalink)
Merc63 wants to know Dino or Syn?
What's DIN?
Merc63 is offline   Quick reply to this message
Old 12-12-2012, 05:49 AM   #3 (permalink)
strokerjlk's Avatar
Originally Posted by Merc63 View Post
What's DIN?
DIN ...German Institute for Standardization is the German national organization for standardization
And there are several other correction factors.
SAE STD just happens to be the most used in the states.
07 ULTRA
AMRA
SE 218
DR 218
strokerjlk is offline   Quick reply to this message
Old 12-12-2012, 08:19 AM   #4 (permalink)
S&S Cycle's Avatar
Yes there are a few other correction factors, I just listed the two most commonly used here in the USA, Most magizines and parts manufacturers use the STD method, because of the inflated numbers. At S&S we publish only SAE numbers.
Old 12-12-2012, 04:08 PM   #5 (permalink)
Iron Butt
Bronxhog's Avatar
Bronxhog wants to know Dino or Syn?
thank you and keep the information coming
Bronxhog is offline   Quick reply to this message
Old 12-12-2012, 08:22 PM   #6 (permalink)
Axe Man
BVBOB's Avatar
And you will note in the above sticky that we only accept SAE dyno reports here. STD or others are ok if accompanied by the SAE report.
Numbers are just numbers no matter what the report, I'm guessing the Superflows in La Crosse didn't read anything near what the Dynojet at Viola will on the same bike either. The Superflow at least uses a calibrated torque link and can give a realistic reading while the dynojet is strictly(unless further equipped) an inertia dyno.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
BVBOB is offline   Quick reply to this message
Old 12-13-2012, 06:09 AM   #7 (permalink)
Outsider
Half_crazy's Avatar
Half_crazy wants to know Dino or Syn?
The difference on my charts between SAE and STD is 2.25% on the same pull.
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged
stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes
airbox, RPW Thor pipe, Lloydz ECU, PC-III, Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
Half_crazy is offline   Quick reply to this message
Old 12-13-2012, 10:45 PM   #8 (permalink)
INDEPENDENT 1 wants to know Dino or Syn?
Welcome to the forum, S&S. I love your products and my Factory Pro dyno.
INDEPENDENT 1 is offline   Quick reply to this message
Old 01-05-2013, 01:45 PM   #9 (permalink)
qwiteklever's Avatar
qwiteklever wants to know Dino or Syn?
just had dyno on 12 deluxe, stock 103ci, se stage 1 hi flo kit, kn air filter and v&h hs slip ons. final run with sae factor of 3....max power 75.09 , max torque 96.15. just bought rinehart exhaust and will have a retest in spring.
qwiteklever is offline   Quick reply to this message
Old 08-31-2013, 10:14 AM   #10 (permalink)
porksword's Avatar
porksword wants to know Dino or Syn?
Depends on your altitude ! I have spent 1000s hours on dynojet 250 I , and I am at 5400 elevation , and STD - SAE are about the same. Sometimes SAE will show 1/2 hp. more. I always use SAE , maybe someone knows why. One thing you DONT want to use is , 'uncorrected' !!! LOL.. If you pull 100 hp. SAE , you will be lucky to get 85 uncorrected. You will ALWAYS see 1-3 more TQ. on the dyno after it warms up , 200+ degree , from the first , cold pull. Stench
porksword is offline   Quick reply to this message
Old 08-31-2013, 11:10 AM   #11 (permalink)
strokerjlk's Avatar
depends on the conditions.
uncorrected is always 1.0 correction factor or no correction factor.(thats why its called uncorrected)
if your sae or std correction factor is less than 1.0 ( like 0.99) the uncorrected will be higher.if the sae or std correction factor is 1.01 or larger then uncorrected will be lower.
so to say uncorrected is always higher isnt correct. I see it swing both ways here. that why its called a correction factor.
there is no sae c/f of 3
3 is the smoothing of the curves
07 ULTRA
AMRA
SE 218
DR 218
Old 08-31-2013, 11:46 AM   #12 (permalink)
FXDRYDR is still riding a stock bike FXDRYDR is still riding a stock bike
Never knew those rascals swing both ways!!
Back to programming - so then, is "Actual" just the uncorrected?
FXDRYDR
2003 FXD
124
Black, chrome & loud.
FXDRYDR is offline   Quick reply to this message
Old 08-31-2013, 12:05 PM   #13 (permalink)
Olivepearl wants to know Dino or Syn?
Ok I pulled 3 sheets from two tuners in two different states both here in the Deep South. 1st is the 120R 2nd is a 117, 3rd 117
120R
70.44 F
24.62 in-hg
SAE 1.22 humidity 7%
SAE smoothing 5
HP 145.95
TQ 140.15
117
92.35 F
30.04 in-hg
STD 1.02 humidity 18%
STD smoothing 5
HP 138.39
TQ 143.05
117
64.72 F
30.07 in-hg
uncorrected 1.00 humidity 12%
HP 155.61
TQ 143.48
Explain the Differences and if One is better to produce the Bigger Numbers. As you can see the 120R correction is 1.22 SAE and the 117 is STD 1.02 are they both boosting the numbers doing it this way?
Thanks RT
Olivepearl is offline   Quick reply to this message
Old 08-31-2013, 06:02 PM   #14 (permalink)
Ollies930 wants to know Dino or Syn?
I find it difficult to trust a correction factor of 1.22 with a barometric pressure reading that would be more suited to Denver rather than a southern state. Society of Automotive Engineers states that anything over 7% correction factor becomes inaccurate. 22% correction factor is way away from realistic.
As for boosting numbers, anytime the correction factor is above 1.00, the numbers will be higher than the actual hp/tq produced and if the correction factor is below 1.00, the numbers shown will be lower than the actual hp/tq produced.
To be able to compare engines to each other, it would be best to run them under similar conditions on the same dyno. Different duno manufacturers are using different math and software to arrive at the way they read hp. Some dynos read higher, some lower. No one is better than the rest (even though they may try to convince you otherwise), they are simply a tuning tool and even though manufacturers are trying to correct the output to be able to be compared from location to location, things as simple as a dyno room fan can ultimately mess with your numbers.
Ollies930 is offline   Quick reply to this message
Old 08-31-2013, 06:13 PM   #15 (permalink)
Ollies good catch, I want to make a correction myself...(pardon the pun) the correction factor I listed at 1.22 was at High Altitude and now they are at or near sea level. My bad I do apologize. In this case it would be comparing apples to oranges. Now back to our regular scheduled programming!!
