Rosa's CycleProCharger.comCellino&Barnes Motorcycle AttorneysHD PipesMetalArtsRacerPartsWholesaleLawTigersWheeldock.comKomodoGear.comCycleGear.comKewlMetal.comMean City CyclesDaytona Twin-Tec
Motorcycle.com
Old 04-06-2008, 02:27 PM   #226 (permalink)
FLHtoFXD's Avatar
FLHtoFXD is on a distinguished road
Thumbs up Just a few mods
Read my sig in addition to this I have a detachable winshield and backrest for the long haul. By the way great forum!
2004 Superglide
95 inch 10.5-1 JE pistons
Branch #4 heads with compression releases
Andrews T55G gear drive cams
Jims roller rockers
Feuling superpump and lifters
DTT TC88A ignition
Mikuni HSR45 carb with 3 inch filter
S.E. adjustable pushrods and tubes
S.E. high tensile cylinder studs
Barnett scorpion clutch
S.E. 2-1 pro pipe with home made baffle
Progressive fork springs and 11 inch black 412's
Sputhe Positrac
Vulcan Mid-glide trees
Headwinds carbon fiber headlight
FLHtoFXD is offline   Reply With Quote
Old 04-06-2008, 08:30 PM   #227 (permalink)
fj1200 is on a distinguished road
Major items
V&H ProPipe HS 2 into 1
Big Bore stage 2 plus SE Performance heads
Corbin Gunfighter and kadt seat
Kuryakyn Panacea light setuo
Kuryakyn Pilot handgrips and footpegs
HD hard bags
second horn
windshield
luggage rack and sissy bar
and lots of decorative pieces
Stephen
2005 FXDXI, SE AC, 95 with flat top pistons, SE-203 cams, SE Performance heads, Vance and Hines Pro Pipe 2 into 1, SE Super Race Tuner
2006 Big Dog Mastiff, S&S 117 - stock engine,Doherty PowerPacc, Hooker Dark Troublemakers
1992 Yamaha FJ1200 - stock engine, Uni filter pods
fj1200 is offline   Reply With Quote
Old 04-11-2008, 09:08 PM   #228 (permalink)
dynajim's Avatar
dynajim is on a distinguished road
Originally Posted by 99DWG View Post
Hello To All:
Chrome Plated Swingarm
Chrome Rear Axle Covers
Rear Stainless Braided Brake Line
Stainless Floating Rotors
Chrome Lower Belt Cover
Chrome Sproket Cover
Bobtail Fender Rack
Front Stainless Braided Brake Line
Chrome Clutch Bracket and Master Cylinder
Chrome Master Cylinder Cover
Chrome Hand Levers
Chrome Hand Switch Covers
Chrome Lower Sliders
Chrome FX Brake Pedal Pad
Airfoil Passenger Pegs
Airfoil Rider Pegs
Airfoil Shifter Peg
Bar and Shield Air Cleaner Cover
Detachable Windshield
Screaming Eagle Carb kit with K/N filter
Chrome Turn Signal Swivel Assembly
Turn Signal Visors
Kuryakyn ISO Grips with Throttle Boss
4 1/2" Pullback Handlebar Risers
Leather Tank Panel with Pouch
Chrome Headlamp Visor
Taillight with Blue Dot
Willie and Max Saddlebags - Deluxe Slant
Vistar Cruise Control
Deep Bucket Sundowner Seat
Smooth Bucket passanger pad
8.5 mm Magencor plug wires
Wants:
11" lowering shocks
Samson Street Sweepers
Whatever else will make the wife mad....
How to handle the wife: I bought it! But I still need more. Complain some more and I'll buy some more now!
Actual answer: Well, I really needed it! Honest!!
'04 FXDWGI
95 HO
SE heads
SE Adj. Pushrods
SE Lifters
SE 10:5/1 Forged Pistons
SE Intake & AF
SE257 cams
PC IIIUSB
Python 3's
So much other stuff I've lost track
dynajim is offline   Reply With Quote
Old 04-27-2008, 11:58 PM   #229 (permalink)
WS6 Formula's Avatar
WS6 Formula is on a distinguished road
2006 Harley Davidson Dyna Low Rider
Dragonfly Green Pearl & Vivid Black
(Custom paint 1 of 233 only available Jan - Mar 2006)
(Before photos have reflectors and belt guards removed)
*Arlen Ness Big Sucker I air filter kit P/N AN18-505
*Cut off the original air filter outer cover
*D&D Fat Cat 2 into 1 exhaust with quiet baffle P/N 496-32B
*H.D. Screamin’ Eagle Performance Exhaust Gasket Kit P/N 17048-98
*H.D. Screamin Eagle Race Tuner P/N 32107-01E (base map # 141NX002 is for 8* injectors but using 25* injectors, +AFR, +VE, +Timing, - Cranking Fuel, - Idle, +Accel Enrichment, - Decel Enleanment)
*H.D. Screamin Eagle spark plug wires with home made supports P/N 31937-99A
*Billet finned timing cover (from eBay seller gregg5869)
*H.D. 2006 Wide Glide 21" front wheel (New take off from eBay)
*H.D. 2006 Wide Glide triple clamp upper P/N 46700-06
*H.D. 2006 Wide Glide triple clamp lower P/N 46386-06
*H.D. 2006 Wide Glide axle P/N 40923-06
*H.D. Chrome Tapered Front Wheel Spacer Kit P/N 41410-06
*Kuryakyn Front Axle Nut Covers P/N 1213
*H.D. 2005 Forward control kit P/N 49080-03
*H.D. 2006 Polished Stainless Steel Gear Shift Linkage P/N 33815-06
*Removed the original shift lever without removing the primary
*H.D. 2007 Screamin Eagle Springer foot pegs P/N 52317-07
*H.D. 2007 Screamin Eagle Springer brake pedal P/N 42574-07
*H.D. 2007 Screamin Eagle Springer shifter peg P/N 49268-07
*H.D. 2007 Screamin Eagle Dyna Polished Stainless Steel Footpeg Mounting Pins P/N 42679-01
*Grinded down rear foot peg stops so pegs will tilt in more when in the up position
*H.D. Aileron Hand Grips P/N 56425-02
*H.D. Chrome Switch Cap Kit P/N 71804-03
*Routed control wiring inside handle bars
*Routed front frame and console wire harnesses to left side of the bike
*Redressed all harnesses, cables, and hoses
*Removed reflectors, all factory decals, VIN, and emissions labels, and vapor canister
*Modified lower belt guard
*Lay down pyramid license plate mount P/N 4626469427
*Trimmed license plate to fit inside mount
*H.D. Tinted turn signal lenses P/N 69304-02 , painted turn signal reflector and internal housing flat black
*Kuryakyn Deluxe Smoked Tail Light P/N 4974 , painted led light face plate and inside of lens sides flat black
*Relocated horn using rear engine mount bolt
*Added a relay connected to high beam lead to trigger garage door opener
*Installed banana jack on bottom of coil cover for battery tender
*H.D. 2006 Deuce headlight (New take off from eBay)
*H.D. 2006 Sportster Custom, headlight mount P/N 67919-96
*Sylvania Silverstar H4 bulb
*Added a bushing between the lower headlight tabs (So tabs will not bend over)
*H.D. Script Battery Cover Band P/N 66443-06
*H.D. 2008 Screamin Eagle Dyna front turn signal mounts P/N 68266-03
*H.D. 2008 Screamin Eagle Dyna Spun Aluminum Face 4" Speedometer - MPH P/N 67516-04B
*H.D. 2008 Screamin Eagle Dyna Spun Aluminum Face 4" Tachometer- RPM P/N 67522-04A
*H.D. Smooth LED Fuel Gauge P/N 75237-03
*Tank lift 1.60"
*H.D. Classic Chrome Brake Caliper Insert P/N 44477-99
*H.D. Script Rear Axle Cover Kit P/N 44346-06
*H.D. Chrome Tapered Rear Wheel Spacer Kit P/N 41411-06
*H.D. 2007 Low Profile Touring Shocks P/N 54631-02B
*Dunlop Screamin Eagle Rear GT502 180/60B17 P/N 43197-04A
*Dunlop 17" Tube P/N 40502-06
*Dunlop 17" Rim Strip P/N 43101-06
*Avon Venom 90/90B-21 FRONT (AV318)
*Dunlop 21" inner tube P/N 43140-80
*Dunlop 21" rim strip P/N 43939-89
*Lyndell Z Brake Pads P/N 1720-0022
WS6 Formula is offline   Reply With Quote
Old 05-03-2008, 10:04 AM   #230 (permalink)
dynajohn is on a distinguished road
03 FXDX sport, 124 C.I. T-Man motor
4-1/4 bore X 4-3/8 stroke
Pro Street stainless pipes
Wood 50.5mm modified carb & air cleaner package
S&S D manifold modified by T-Man
Wood W-68 cams & T-Man springs
Baisley 1.7/1 rocker arms & lash caps
solid lifters
T-Man modified HD 103+ heads--2.1" int, 1.65" exh
comp. releases
Revolution cylinders
CP pistons 11.4/1
piston oilers
Hoban Bros. HD crank/lightned/balanced/pinned
Timken case bearing mod
T-Man modified crankcase breather system
Andrews 2.94 1st gear.
Transmission modified for reverse shift pattern with Baker electric shift.
oversize pinion gear
Tech 2-KW starter
dual oil coolers with bypasses
chain drive conversion with 3.36 final ratio
Race Tech modified front forks
Works shocks
Sputhe positrac kit
Steering stabalizer
fork brace
Autometer Pro Cycle tach & speedometer
drag bars
cubic money
dynajohn is offline   Reply With Quote
Old 05-05-2008, 08:33 PM   #231 (permalink)
harley_fixer is on a distinguished road
I need some info on installing floorboards on a 99 DYNA. Anyone?
harley_fixer is offline   Reply With Quote
Old 05-06-2008, 11:12 PM   #232 (permalink)
leauxridah
I also need to know if anyone has tried to install some footboards on a Fat Bob with forward controls. Or any Dyna for that matter. Let us know. Thanks.
[IMG]http://205.214.91.71/forums/attachment.php? (leauxridah is cajun french for LOW RIDER)
leauxridah is offline   Reply With Quote
Old 05-09-2008, 03:22 PM   #233 (permalink)
rdgzoe's Avatar
rdgzoe is on a distinguished road
I have a street bob so I guess I should keep it "bobbed out"
Maybe a detachable luggage rack and I would like to get the passenger pillion detachable to.
rdgzoe is offline   Reply With Quote
Old 05-22-2008, 07:54 AM   #234 (permalink)
wrecker's Avatar
wrecker is on a distinguished road
er guess its easier form Me to list whats still stock ?
`96 frame, trans casing
switch gear housings
brake and clutch lever ( but polished )
Tank and rear mudguard and rear turn signals
rear pulley rear disc and rear brake claiper
er thats about it
wrecker is offline   Reply With Quote
Old 06-21-2008, 04:52 PM   #235 (permalink)
03fxd is on a distinguished road
2003 FXD:
10" mini apes
chrome controls
steel braided cables
wire wheels
foreward controls
V&H big shots
LED everything
luggage rack and tall sissy bar
saddleman seat
chrome engine covers ( ok only half have been changed over so far )
S&S E carb.
11" shocks
high volume oil pump, PSI indicator, and other misc. engine stuff. (all functional not performance)
Tach addition
adjustable pushrods
03fxd is offline   Reply With Quote
Old 06-21-2008, 06:46 PM   #236 (permalink)
WS6, man, its good to see that beautiful bike again. had it for a desktop background forever, what can i say?????????? i still love that bike.
Old 06-30-2008, 11:54 PM   #237 (permalink)
flstcruss's Avatar
flstcruss is on a distinguished road
Talking
WS6 very nice ride (hope u dont minde if I use some of your ideas)! Would you please give further info on the Horn Relocation.
Thanks Russ
flstcruss is offline   Reply With Quote
Old 07-20-2008, 12:05 PM   #238 (permalink)
tranedlr2 is on a distinguished road
Hi there. New to this forum so I'll introduce my ride. 2000 FXD, black. Stock engine, so far, but here are the mods. Kurykyn extended forward controls. Mustang wide vintage seat with tank bib and tall backrest. NationalCycles beaded windshield. Sportster buckhorn handle bars. Swapped out narrow glide for a wideglide front end w/ 3 degrees of rake. 16 130 metzler on the front, 16 150 on the back. Fat boy front fender with chrome trim. 7" Fatboy headlight. Kurykyn grips and pegs w/stirrups.Screamin eagle filter kit and ignition modual. Caliber 2to1 exhaust. Kentucky saddle bags and quick mounts. Chrome luggage rack. HD chrome axle covers. Kuryakyn starte cover. Hd chrome dash cover, front axle covers,battery cover, ignion cover, coil cover. I know there's more, but I'm tired of typing. Have had the bike for 7 years and 50,000 miles. It's great to see all the dyna riders on this sight.
tranedlr2 is offline   Reply With Quote
Old 08-18-2008, 02:06 PM   #239 (permalink)
118811's Avatar
118811 is on a distinguished road
Smile 2001 FXDWG can someone post pics for me!?
hello
Got my first Harley 10 days ago!!
I have told slot of it I'd custom/aftemarket
I know the seat and ehaust are
Let me know if you help with pics!!
Aloha from Honolulu
118811 is offline   Reply With Quote
Old 08-24-2008, 04:35 PM   #240 (permalink)
hoss1059 is on a distinguished road
Ok, currently my '06 SG has the following:
SE II's gutted (Rush slashcuts in route)
PC III
SE Filter
Pillion seat and pegs
Highway pegs
Night Train drag bars, chrome switches, housings, new grips, mirrors
3" tank lift kit (a must, changes the whole look of the bike)
Chrome center console (in route)
Chrome belt guard (in route)
Bobtail fender kit
Custom paint, candy apple red with real flames, two skulls on tank and one on front fender. Rear fender reads, "Born to Sin, How Am I Doing?"
180 wide tire kit
Chrome is next (isn't it always?)
2006 Super Glide - Bobtail kit, SE II's & filter, Night Train Drags, PC III, wide tire kit, custom paint.
My precious...
1986 Honda Shadow VT 700
hoss1059 is offline   Reply With Quote
