» Buyers Guides |
02-24-2005, 11:25 AM
#46 (permalink)
Any updates now that winter bike mods are finnishing up?
02-24-2005, 11:51 AM
#47 (permalink)
10" pullback drag bars
upgrade bullet turn signals with smoke lenses
Corbin classic solo (not shown)
AN big sucker (not shown)
forward controls
a simple bike for a simple mind
"What is called an educated person is often someone who has had a dangerously superficial exposure to a wide spectrum of subjects"........
02-24-2005, 12:45 PM
#48 (permalink)
2005 Dyna Wide Glide EFI
tons of chrome
chrome front end
sway back drag style bars
Badlander seat
HD Custom shop paint job
Hey AzFal, how do you like the V&H staggered Big shots? what do they sound like? Did you also replace your air filter?
02-24-2005, 02:04 PM
#49 (permalink)
tons of chrome
chrome front end
Badlander seat
I don't know what AzFal thinks of his pipes, but I own Python Staggereds (made by V&H) and they sound great! They are very throaty and many people have told me they loved 'em. But, they might be a bit too loud. I actually wear earplugs (and that's with a full-face helmet!). I've ordered the Silent Baffles to tone it down a bit. If you haven't done it yet, go to the V&H site and listen to the Big Shot Staggereds. Good luck.
02-24-2005, 11:33 PM
#50 (permalink)
Livin' Free Indeed
tons of chrome
chrome front end
Badlander seat
Nice lookin' wide glide Doug. I definitely like the Big Shots. They have a nice deep, throaty sound to them. I've had a few people volunteer how good they sounded. I don't think they're too loud. The neighbors hear me leave for work at 5 a.m., but hey, it's a Harley!!!
How'd you know I replaced my air filter?! Yes I did. I run an exposed filter with the Rammer a/c cover made by Deweys Pegs. BTW I decided I did need more power & torque after all. I'll be doing a 95" next month.
Dave
Dave
"All that is necessary for evil to triumph is for good men to do nothing" Edmund Burke
"Those who will not be governed by God will be ruled by tyrants" William Penn
'02 WG Lowrider
95" Wiseco Flat-top pistons
Dewey's Pro-Street headwork
37G cams
DTT ignition
44CV Carb & 51mm a/c
Cycle Shack slip-ons
02-25-2005, 06:22 AM
#51 (permalink)
Stage 1
V&H Pro Pipe HS
Bar Enterprises Solo Seat
Motherswell fender rack
Next up:
Boss Bags
Windvest
Progressive 440HD
maybe different handlebars
02-25-2005, 12:30 PM
#52 (permalink)
Dave
I was only guessing because I know when you replace pipes you want to complete the air flow cycle which starts at the air filter. good air in, bad air out. Being a California bike the EPA clamps the exhaust so it's sounds like a Vespa, well a very angry Vespa. I want it to sound and perform like a V Twin should. I like the look of the staggered pipes as well. That's next up for me along with lowering the bike an inch.
02-25-2005, 02:09 PM
#53 (permalink)
Originally Posted by PlanetX
Stage 1
V&H Pro Pipe HS
Next up:
Boss Bags
Windvest
Progressive 440HD
Check your Private Messages.
03-07-2005, 11:07 PM
#54 (permalink)
03 Wideglide, gunmetal
hd detach, windshield
kuryaken 3"forward control ext.
saddle bags tach/speedo comb. unit
airfoil footpegs (all 4)
K&N high floww air filter
zippers huge ugly chrome air cleaner cover
bobtail rack
mustang seat
Now where the money went!!
95" SE high comp forged pistons
stock ported and flowed heads
42mm mikuni carb
woods tw6hg cams
SE adj. pushrods
SE selectable ign.
stock headpipes w/SEII opened up mufflers
3.75 primary gearing
baker OD6 6speed gear set
I'm missing a couple things but thats all I can think of right now!
03-08-2005, 10:38 PM
#55 (permalink)
Silver Black 03 with the following upgrades
Alarm
HD Removable Windshield
Oil Cooler
Chrome Oil filter mount with oil cooler takeoff fittings and built in thermostat
Oil Temp dip stick
HD Oil Pressure gauge with line upgraded to Russel Braided
PIA- Hi Output Halogen headlight bulb
Rear turn signal to brake light conversion module
SE AirCleaner
SE II Slip Ons
SE0203 Cam
S&S IST Ignition
Mikuni HSR42 Carb
Magnum Sterling Chromite braided plug wires
HB125 Primary Chain Tensioner
AC Cover Insert used as an air filter cover
Kuryakyn flush mount LED Gas Gauge/Volt Meter
MAtching Flush mount gas cap
Dash Acorn Nut
Chrome Fork Tube and Stem nut covers
HD Fat Mini Ape Bars with Internal wiring
HD Risers for Chubby apes
HD Minnie tach with bracket modded to fit HD Chubby risers
Chrome brake/Clutch levers
Chrome Front Turn signal mount blocks
Running Lights
Deep Bezels for running lights and headlights
Bungie Nuts on rear siderails
HD Rear luggage rack
Mustang Wide Touring solo seat with Backrest
Mustang leather fender bib
Race-Tech Front Fork Springs
Race Tech Gold Valve Cartridge Emulators
SE Front Fork Brace
HD Flame Billet Rider/Passenger Pegs and Shifter pegs
HD Driver Heel Rests for mid controls (work fine on forward controls too)
Kuryakyn Highway Pegs with HD Flame billet pegs
Chrome bolt set for Primary Cover
Chrome bolt set for Cam Cover
Chrome Bolts for all footpegs
Chrome rear axle covers
AustinFXDWG
2005 FLTRi Road Glide - 95", SE Flat-tops, SE-AC, SEPro Slipons, Bassani Power Curve True Duals, Dynojet PCIII, HD Oil cooler, Mustang Touring Solo saddle, Fog Lamps, and HogTunes Speaker. Now we';re cruisin'...
Reason: added missing stuff
03-09-2005, 03:39 PM
#56 (permalink)
Dyna mods
2004 FXDL
Vivid Black/Wire wheels
SE ignition module
SE high flow air cleaner
Carb rejet
SE slip on mufflers
Chrome dash panel
No pics for me but appreciate all the posts.
03-09-2005, 04:29 PM
#57 (permalink)
04 FXDLI
Drag Bars
Short Shot exhaust
Lower scoop with custom paint
Rear Blinkers relocated
LePera solo
21 inch slotted rim
18 inch slotted back
chrome swingarm
chrome dash and switch housing
7inch bullet headlight
forwards
rear lowering kit
pegs front and rear
That's about it for now.
James
Before and after pics.
Live life to the fullest, cause you only get one chance to do it RIGHT!
03-19-2005, 04:21 PM
#58 (permalink)
My accessories and saddlebags
Here's my 04' WG. I have the following:
1. Progressive 1" front lowered springs
2. HD chrome lowers
3. 1" lower HD (Fox) rear shocks (doesn't bottom out, and handles perfectly)
4. Leatherworks 112+2" saddlebags (ask me I'm a rep!)
5. Vance and Hines Bigshots staggered
6. Stage 1 remap chip
7. High flow air cleaner (14 HP gain with pipes, remap and cleaner!)
8. Corbin gunfighter and lady seat
9. Full size detachable windscreen
10. Kuryakyn 3" extended controls
11. Kuryakyn pegs (switchpegs front, it's a great new product)
12. Oil pressure gauge
13. HD heated adjustable grips
14. Powerlet chrome electrical accessory plug in
15. HD rear rack
16. Tachometer
17. Front and rear turnsignal relocation
18. Leatherworks 118's
19. Leatherworks 95
If anyone has questions on any of this, I have good information on this stuff.
Reason: change
03-19-2005, 10:03 PM
#59 (permalink)
2005 FXDI Black
Chrome Longhorn Handlebars
Extended front brakeline
Highway pegs
Tachometer Kit
Works Performance Shocks
Dyna Rigid Mount Leather Saddlebags
Turn Signal Relocation Kit
Sundowner seat
Quick release Windshield
Billet chrome cable clamp
Floating brake disks front & rear
Chrome sideplates/tall sissy bar/pad
Full front fender (not shown in picture)
95 cu Stage 1 Kit/reprogramming
03-19-2005, 10:17 PM
#60 (permalink)
Phemus
The devil made me say the Propipe adds about 18hp. I have no idea where that figure came from...more like 6hp. I think...
