Wheeldock.comCellino&Barnes Motorcycle AttorneysMetalArtsCheapCycleParts.comStoneyStraps.comPro PadTech N' Cycle GearBikeBanditRosa's CycleAdvanstarMotorcycleShowsSpringfield ArmoryProCharger.comPerformanceOilTech
Wheeldock.com
Old 07-17-2004, 09:01 PM   #31 (permalink)
TxMajik
Originally Posted by wolfe47374
obvious misc. chrome peices
Heritage Classic bars
Mustang Vintage Seats
HD Backrest
Front Spoiler
Home Made 2" tank Lift
Stage 1 w/ V&H BS Staggereds
Man there are some awesome bikes out there!
Wolfe, when you did the 2" tank lift did you notice any difference in your center of gravity or handling? I think my '02 FXDL needs a tank lift (among many other things to keep up with you guys!)
Old_Mil, How do you like the fork brace?
TxMajik
TxMajik is offline   Reply With Quote
Old 07-18-2004, 02:54 AM   #32 (permalink)
Livin' Free Indeed
AzFAL
Here goes:
'02 FXDL
Hance & Hines Bigshot Staggered pipes
BossBags #31 detachable saddlebags
Stage 1 carb upgrade
Metzler ME880 tires
Kuryakyn Magnum mirrors
Buffalo Bars t-bar handlebars
Kuryakyn front turn signal relocation brackets
HD smoked turn signal lenses
HD chrome lower fork legs
Screamin' Eagle heavy duty fork oil
HD chrome coil cover
HD chrome lower belt guard
Chrome pulley cover
HD billet footpegs
HD forward controls kit
Removed headlight eyebrow & mounted a '89 softtail headlight onto lower tree. Traded out the stock innards to put into the '89 housing. Disconnected all the indicator lights except for the oil pressure light, drilled a hole in the tank dash & mounted it there.
Had seat re-covered & riders portion lowered & moved back & passenger area built up w/ more padding & widened. Backrest pad re-covered to match seat.
Moved rear turn signals using lay down license plate & turn signal relocation kit for an FXDX or FXD, can't remember which. Had to drill out threads in turn signal housings & use nuts to attach housings to the turn signal stem. Thead pitch was not the same on the stem as on the turn signal housings.
With the exception of my chrome lower fork legs all non-stock mods & accessories were done by myself. A friend more knowledgeable than I helped me with the fork legs.
I think I'm done for a while now. Don't see the need for any engine work. I've been a little over 120 mph a few times & can't see the need for more speed & can get up & go in quite a hurry also. When I need to re-build someday I'll probably go to a 103" & gear driven cams & such.
Maybe a mid or wide glide front end & some apes someday? Maybe some chrome billet wheels, a 21" front wheel who knows what the future holds!!!???
For now I'm very happy & over spent. (For now)
Will try to get a pic of the bike w/ the BossBags on in the next few days.
Dave
AzFAL is offline   Reply With Quote
Old 07-19-2004, 06:42 PM   #33 (permalink)
Yogi_Bear_79
1996 FXDWG
Purchased new in June 96
58,500 miles currently
See this post for more details about the convertability built into this cruiser/touring bike. Pic's in that post are before the pipes, air cleaner change, and complete new front end.
http://www.v-twinforum.com/forums/sh...ad.php?t=29025
- Fat Katz Vegas Front Fender
- Fat Katz Rapture Rear Fender
- American Wire Wheel 100 Spoke Radial Laced 21" Front
- HD Chrome Slotted Rear Wheel (Bad Boy Style)
- Braking Satin Stainless Steel Front Rotor
-OEM HD Front Slotted/Drilled Front Rotor Polished and modified to run on
rear (matches rear wheel perfectly)
- Chrome Duece Legs
- White Brothers 2" Progressive Drop Springs in front
- Progressive Suspension 11.5" 418's
- Custom Cycle Enginering Billet Aluminum Chrome Trees
- Kury Aykn Turn Signal Mirrors
- HD Foam Grips
- Wind Vest 16" Screen
- Chrome OEM 2000 & Up front Brake Caliper
- Kury Aykn ISO Pegs with long horn extensions in front, w/ matching brake
pedal and shifter peg
- Chrome Braided Front Brake Line
- S&S Super E
- V&H Pro Pipe
- Andrews CAM
- Purple/Chrome Braided Plug Wires
- Kury Aykn bullet lights in rear (serve as running/brake/signals)
- Home Made Side Mount License Plate Bracket with LED Licesne Plate Light
- HD Saddle Bags
- HD two piece bucket seat
- JD Fabrications Removeable back rest mount w/HD sissybar & pad
- HD luggage rack mounted to sissybar
- Custom Purple Candy w/Tribal Flames
- Painted to match custom dash, side covers, struts
- Fender Nut Eliminator Kit from Ghost Brackets (Allow removal of saddle bags
with just an allen wrench, 5 min job)
Yogi_Bear_79 is offline   Reply With Quote
Old 07-20-2004, 08:56 PM   #34 (permalink)
W.C.mach is on a distinguished road
I only made a few mod's Check it out here
Motor:
103CI
S&S 585 cams
roller rockers
ported heads
SE 2into1 pipe
110 HP 111 FTLBS
Rivera pro clutch
6 Speed trans
Chain final drive
Chassis:
JML amuminum swing arm
Works proracer shocks
SE fork brace
Steering dampener
PM 6 Piston calipers
Braking 13" wave rotors
Braided lines
Wheel & tires:
PM monaco 4.25X18 Rear
PM Monaco 3.0X18 Front
Metzler MEZ4 160/80-18
Metzler MEZ6 120/70-18
I moved the pegs back 3.0" and made a new brake and shift lever.
The front fender is from a Buell Blast with custom brackets. Warren
W.C.mach is offline   Reply With Quote
Old 07-25-2004, 12:53 PM   #35 (permalink)
Wide1 is on a distinguished road
16" apes CHROME
HD Exotic Seat
HD Billet Series Grips/Pegs
BUB Chamber Maid Pipes
ALL SS Cables
My Gallery for larger pics
Wide1 is offline   Reply With Quote
Old 08-17-2004, 12:41 AM   #36 (permalink)
M1Tanker is on a distinguished road
My 2004 Super Glide mods include:
Wernimont "Long Shot" front fender
Detachable HD Windshield
HD Auxiliary Lamp Kit (Halogen)
Engine guard w HD Diamond Highway pegs
Burly Bikini bars
4.5" pullback risers
Clock clamp
HD Diamond Plate grips and pegs
Braided clutch, brake, and throttle cables
Chrome Switch Housing kit from Drag Specialties
Corbin Classic Solo seat w/backrest
HD Sundowner seat for 2-up w/detachable backrest and luggage rack
Python Dual Staggereds
Arlen Ness Big Sucker
11.5" Progressive 440 shocks
HD Synthetic Leather Saddlebags
Also, various chrome HD parts.
What's next? How much time do I have!
Here are pics as of a few days ago. Still go a ways to go!
Cya on the road,
Rich
Our Harleys
M1Tanker is offline   Reply With Quote
Old 08-17-2004, 10:12 PM   #37 (permalink)
pops
Accessories / Modifications on your DYNA
98' Superglide. Just chrome,tin and paint mods mostly, done by me.
CRUSTY OLD FART
pops is offline   Reply With Quote
Old 08-17-2004, 10:15 PM   #38 (permalink)
VERY nice Pops!
Cya on the road,
Rich
Our Harleys
Old 08-17-2004, 11:01 PM   #39 (permalink)
pops
Originally Posted by M1Tanker
VERY nice Pops!
Thanks Tanker, sure must be nice to have your SO riding on her own bike
instead of the seat behind you. Something about a woman riding a Harley.....
CRUSTY OLD FART
Old 08-20-2004, 07:47 PM   #40 (permalink)
topchop
My Dyna
Black Paint
Performance Machine Brakes
Progressive 11" rear shocks
Progressive front lowering kit
Drag bars and pull backs
Arlen Ness Grips
BadLander Seat
Cats Eye Taillight
Kuraykn Rear Turn Signals
Drag Pipes
Drag Specialties Oil Pressure Gauge
Custom Chrome rocker boxes and tappet blocks
Misc. Chrome HD parts. etc..etc..etc
topchop is offline   Reply With Quote
Old 08-30-2004, 11:05 PM   #41 (permalink)
LVFXDWG
'04 Fxdwg
95" BB kit
HTCC pistons
HTCC Heads w/ comp release
211 cams
42 MM Mikuni carb w/ intake manifold
Kuryakyn Hypercharger.
SE Ignition module
V & H Straight shots
mirror chrome thunderstar wheels
Kuryakyn ISO grips and pegs
Chrome low profile HD adj shocks
mini tach
Chrome covers: dash panel, sproket, transmission interface, voltage reg, axle covers lower belt cover ( on order) etc.
Detachable memphis shades windshield
Kuryakyn fuel gauge and gas cap
Luggage rack
Kuryakyn LED rear lights
Next SEAT!!! Stock seat sucks!!
LVFXDWG is offline   Reply With Quote
Old 08-31-2004, 09:01 PM   #42 (permalink)
Phemus
steveusmc's Avatar
steveusmc is on a distinguished road
95 FXDWG...Custom
-EV-27 Andrews Cam
-Kuryakyn Hypercharger
-Vance & Hines ProPipe
-Custom billet forward controls
-Arlen Ness: Drag Bars, grips, headlight, taillight and license plate
-Revtech Performance Brakes
-Polished Aluminum, one of a kind wheels. Changed to a 19" front wheel from stock 21".
-Carlini Torque Arm
-House of Kolor custom paint by "Colormania"
-Kuryakyn mirrors with the LED turn signals in the housing..they are GREAT
-Chrome: Swing arm, rear sprocket, primary inner and outer covers, tranny cover, battery cover and top, coil and electronic box covers, cam cover, fully chromed forks, billet triple tree, all bolts covered with chrome caps..everything that can be chrome..is chrome.
-Runs like a scalded dog when you want it. The V&H ProPipe is the BEST sound and adds approx 18hp.
This is the gift my wife gave me upon my retirement after 30 years in the Corps.
Semper Fi,
Steve...in Pensacola
steveusmc is offline   Reply With Quote
Old 08-31-2004, 09:35 PM   #43 (permalink)
Phemus
steveusmc's Avatar
Follow-up
P.S. Those oil spots above are NOT from my Wideglide. :-)
Semper Fi,
Steve
Old 09-11-2004, 06:04 PM   #44 (permalink)
PHUCKING BIKER!
tequacha is an unknown quantity at this point
2000 fxdx storz steering dampener, carls speed shop heads, dougterys breather and vents,woods 41.5 rebel carb, s.e. pushrods, s.e. big bore cylinders,s.e. 103 fly wheels, s.s. 2 into 1 supertrapp w 26 disc, .570 s&s gear drive cams, jims 6 speed .84 to 1, removable wind shield and fairing, removable bit*h bar metzler 880 front and back, greatful dead steal your face derby cover. 1.4 s.e. starter. S&S ist ignition, s&s speedo recalibration module
tequacha is offline   Reply With Quote
Old 09-14-2004, 09:33 AM   #45 (permalink)
Smuggler
Hey pops,
Can you offer a few more details on that beautifully done ride. I can see 440 progressive shocks on rear. Stock height? Lowered? what front end is that? stock tubes in wide glide trees? Looks to have a bit more rake then stock? raked trees, how much. Man Pops you sure made that FXD Purdy!!!
Thanks for any info you care to offer.
Appreciated.
