Progressive Insurance
Mean City CyclesRosa's CycleMotorcycle.com Classifieds!AdvanstarMotorcycleShowsSportbikeTrackGearSpringfield ArmoryPro PadMotorcycle.comExtreme Custom EngravingDaytona Twin-Tec
Daytona Twin-Tec
Old 11-15-2008, 12:42 PM   #1 (permalink)
harleybeg is on a distinguished road
couple of issues
i have a streetbob 08 and i am having trouble locking the front
wheel. i just won't do it. at first i didn't have a problem w/ this.
the other thing issue is when riding only my left mirror shakes
at speeds of 30-50 so much so that the image behind me is totally blurred. this is the same side where i hear a strange buzzing when i apply the front brake (the left side).
i checked for any loose spots but didn't find any.
does anyone have advice?
harleybeg is offline   Reply With Quote
Old 11-15-2008, 12:49 PM   #2 (permalink)
I'm Your Huckleberry
Mr Cujo's Avatar
Mr Cujo is on a distinguished road
No help on locking..
Mirror.. are there small screws on the backside of the mirror? if so they may be loose..SLIGHT adjustments might be in order.
Alternatively, I'd look HARD at the brakes for loose, cracked, damaged components. These vibrating may be related to the mirror, but I'd suspect that you'd feel it in your hands as well. You didn't mention this, so....??
Either way, an abnormal brake noise is a potential life safety issue.. Special attention required...
Cujo
The Fair Tax- (go ahead, click it...you know you want to...)--
'07 Ultra - Arctic White, XIED's, V&H Big Shot Slip-on's, Wicked Hot Blondie, More to come....
Mr Cujo is offline   Reply With Quote
Old 11-15-2008, 02:07 PM   #3 (permalink)
Big Ugly Fat F'n Yankee
BUFFY's Avatar
BUFFY
Mr Cujo, the "buzzing" may be the drilled rotors. Mine does the same thing.
JOHN and his 2001 Screamin' Eagle Wide Glide2 & 2007 Road Glide
You're never too old to have a happy childhood!
BUFFY is offline   Reply With Quote
Old 11-15-2008, 07:04 PM   #4 (permalink)
how far could you lock the front wheel? my best was 160 ft.
Old 11-15-2008, 08:56 PM   #5 (permalink)
Lucky B is on a distinguished road
Mine has the same buzzing noise, and it has had that noise since I picked up the bike from the dealer with 10 miles. When I took it in for its first service I had the dealer take a look at it, and they said there was nothing wrong with it. So I assume that the noise is normal or like Buffy said it could be the drilled rotors. Other than that I have not had any problems with the front brake.
Lucky B is offline   Reply With Quote
Old 11-15-2008, 09:03 PM   #6 (permalink)
DueceDog's Avatar
DueceDog is on a distinguished road
While I don't have the vibration issue, my Deuce does have the buzz sound that comes from the front brake. I've never had a problem with the front brake. It stops just fine and is showing no unusual wear. So, it appears that it's just the nature of the beast. One of winters projects is a new chrome caliper, rotor, and Lydall pads. I'll see if the buzz goes away then.
DueceDog is offline   Reply With Quote
Old 11-15-2008, 09:39 PM   #7 (permalink)
Mr Cujo's Avatar
Waleska huh?? My little brother lives up there.. Maybe we'll wave at each other someday.. You got some nice looking iron there..
Anyway.. buzzing brakes=normal...whattya know.. It's a Harley so it's not only possible but probable...
Cujo
Old 11-16-2008, 04:50 AM   #8 (permalink)
ianz83's Avatar
ianz83 is on a distinguished road
my bike must be too loud. cant hear sh#t
2008 FXDB
96" ci 10:1
Ported Heads
SE stg1 A/C
S&S Slash Cut's
SE 211 Cams
SEST & Daytona Twin Scan2 w/WEGOIIID
ianz83 is offline   Reply With Quote
Old 11-16-2008, 06:44 AM   #9 (permalink)
fastroadking106 is on a distinguished road
Yep the buzz is normal just a drill rotor side affect as far as the fork lock and the viberartion I am worndering if the bike has ever fallen over if so they may be the cause of both those problems I would take the riser clamp off and inspect the bars closely it is posible if it has fallen over the bars are cracked or broken inside the risers this causing the servre viberation on one side also from the fall it could have tweaked the fork tubes in the triple clamps this causing the clamp not to turn far enough to allow you to lock it. just my thoughts
fastroadking106 is offline   Reply With Quote
Old 11-16-2008, 07:29 AM   #10 (permalink)
jmpancoast1 is on a distinguished road
The vibration is part of owning a Dyna, and to many, part of the attraction. I installed a different style mirrors for looks and found they were affected far less by the vibration. The stems on the new mirrors were heavier, which I am sure helped.
The front fork lock may need adjusting and should be covered under warranty. I had trouble with mine getting it to lock. I didn't use it much so I didn't worry about it. I later relocated my ignition switch. When I did this, I loosened the fork lock from the frame to remove the wiring harness. While replacing the fork lock back in the frame, I was able to position it so it was MUCH easier to lock.
To do this, heat the trim ring around the lock with a heat gun to loosen the adhesive. Gently pry the trim ring (very easy to bend) to remove it. Behind the trim ring, you will find a retaining ring with two indentations. They make a specialty tool with two **** to grip these indentations and allow you to unscrew the retaining ring. I used a pair of needle nose pliers and was able to do the same thing. Loosen the lock (no need to completely remove) and play with its alignment. Tighten and re-adhere trim ring.
jmpancoast1 is offline   Reply With Quote
Old 11-16-2008, 10:41 PM   #11 (permalink)
LowRiderCustom's Avatar
LowRiderCustom is on a distinguished road
Ian there's no such thing as too loud when it comes to a Harley.
LowRiderCustom is offline   Reply With Quote
Old 11-17-2008, 05:02 AM   #12 (permalink)
semi-retired
FatBobRob is on a distinguished road
you win
And i thought i was a ballbreaker!
I can't means I won't!
FatBobRob is offline   Reply With Quote
