19" Laced Wheel on a Wide Glide.
I've got a 2000 DWG,.... has anyone here laced a stock Wide Glide hub to a 19 inch rim? Would I have enough clearance at the fender mounting bracket using the slightly wider 19 inch tire, (21" = 3.54" wide - 19" = 4.04" wide) and would I have sufficient tire to fender clearance without a large gap between the tire and fender (21" = 27.10' overall diameter - 19" = 26.41" overall diameter). Would I need to use a Low Rider fender with mounting spacers? Would there be any other clearance issues, like spokes to the backside of the caliper? If anyone has pictures of this setup could you please post them.
Thanks,
Tech23.
