Originally Posted by Shonz14nw
Hi, I have a 93 FXDWG. I have adjusted the clutch etc but still Im getting a cluncking noise as I put her into first gear. I have noticed when the bike is warmed up every now and then she will go into gear no problem as long as it is done slowly. But more times than not it makes that noise. Was wondering if there is a chance the plates are sticking? There is no noise what so ever or problems going into other gears only first. Any and all advise is really appreciated. Also the over flow is leaking petrol even though the tap is off. Not sure what to do there.
Avoid the situations that cause it to clunk..."Don't Do That!" The plates will have some drag, so minimize the effect by shifting to first before you stop; and selecting first gear {clutch pulled} before starting the engine.
Lube the clutch cable and try changing the fluid out with ATF Dextron III, there was a thread on it just recently.
With the leaky carb, try turning the gas off before you stop, plan ahead. Also with the tap, off run the engine till it quits, then turn on the tap and start the engine. This should flush out the needle valve, stopping the leak. Repeat a couple of times as needed.
