ArnottAirRideRacerPartsWholesaleEagleRiderProCharger.comAdvanstarMotorcycleShowsPro PadMean City CyclesMotorcycle.com Classifieds!
Cellino&Barnes Motorcycle Attorneys
Old 10-13-2008, 01:31 PM   #1 (permalink)
LikeWhoaCL is on a distinguished road
Ran fine then quit...Please HELP!
Hello experts,
I just installed a new Rinehart crossback exhaust, kuryakyn hypercharger and dynojet powercommander. This is on an 08 Low Rider. The install went fine. I started it up for the first time... great, started right up no problems or hesitation, powerful, sounded awesome. I let it idle for just a little bit then tested the throttle. Still everything was awesome. Got it up to normal running temp and still everything was great. Shut her down. I was still messy from work so I showerd then got ready for a ride. Started up the second just fine again. Got a 1/4 mile down the road. Stalls. Won't start anymore. The pump kicks on and the starter turns but I only get one fire every maybe 5 seconds. Gas tank is full... double checked the connections everything seems fine, would like to check for leaks but it won't start! Please HELP!!! Thank everyone
LikeWhoaCL is offline   Reply With Quote
Old 10-13-2008, 01:33 PM   #2 (permalink)
Coolmaker's Avatar
Originally Posted by LikeWhoaCL View Post
Hello experts,
Unplug the Dynojet and try it again..
06FLHRCI
Baker DD6
Baker +1 oil pan
BAKER FUNCTION-FORMED™ FL OIL SPOUT
Doherty PACC/Power vents
Fueling Oil Pump
Harley 95" flat tops
Harley roller rockers
SE Forged Rocker Support Plates
Heads CNC'd by NRHS
Odyssey Battery/Charger
Reinhart true duals
S&S 510-G Cams
Sta-Bo bushings
ThunderMax w/auto tune
Old 10-13-2008, 02:55 PM   #3 (permalink)
I did that... still nothing... I got a couple of fires but nothing sustainable or running. I even retrieved the map from the unit to make sure it remembered the map and that it was there and it was. Any other ideas?
Old 10-13-2008, 03:46 PM   #4 (permalink)
JimmyAcorn is on a distinguished road
Re-Map. The Power commander comes with a base setting and it may not be the correct setting.
Peace
JimmyAcorn is offline   Reply With Quote
Old 10-13-2008, 04:24 PM   #5 (permalink)
alright... so my mistake i had only disconnected the power commander at the bike computer. I did double check the map and it was the correct one. Still frustrated I disconnected the other end of the power commander and a bunch of water poured out!!! Obviously from me washing it after the install (get the grim off the chrome!). But the thing thats got me now is, I installed this thing behind the stock computer as much out of the way and with the amount of water that came out sounds like a design issue! Do any of you have this problem... how did you solve it... I think I am just going to wrap it up in electrical tape and hope for the best. Hopefully I won't have this problem everytime the bike needs a bath. Thanks for you help guys.
Old 10-13-2008, 06:14 PM   #6 (permalink)
william.t.dodso is on a distinguished road
I had that problem with mine. We finally greased the connectors and wrapped it with electrical tape. Mine would even cut out on foggy mornings. Once it dried out it runs great.
william.t.dodso is offline   Reply With Quote
Old 10-13-2008, 07:42 PM   #7 (permalink)
Johnny Come Lately
Gulfstream's Avatar
Dielectric grease is your friend!
John Levanger
Old 10-14-2008, 12:48 AM   #8 (permalink)
Coolmaker's Avatar
If you submerge your Ole Lady, she will drown............ Same for your bike...
06FLHRCI
Baker DD6
Baker +1 oil pan
Fueling Oil Pump
Heads CNC'd by NRHS
Reinhart true duals
S&S 510-G Cams
Sta-Bo bushings
Old 10-15-2008, 09:07 AM   #9 (permalink)
Well it all runs great now. I wrapped it up in rubberized duct tape and then again with electrical tape.. so hopfully the connections are all but waterproof. Thanks for the help guys. heres a picture of the completed exhaust and hypercharger!
Old 10-15-2008, 09:26 AM   #10 (permalink)
PR3VS56's Avatar
PR3VS56 is on a distinguished road
That pic is awesome. Nice work!
'05 FLTRI
K&N, SERT, 95" Dave Mackie Mega-Sphere, Feuling oil pump & LMR-002 (Baisley) spring, S&S Crank, S&S Roller Rockers,
black SuperTrapp SuperMeg 2:1 (19 disc closed cap), RIVERA PRIMO Pro-Clutch, SE 6-Speed, Ride-Str8, heated grips
Pri: Amsoil Syn ATF. Trans: Redline Heavy ShockProof. Crank: Redline 20W60HD
105tq/107hp
Proverbs 3:5-6
Fruit of the Spirit
PR3VS56 is offline   Reply With Quote
