Belt Tension
Today I was checking my belt and noticed it was a little loose. So I adjusted it to 3/8 @ 10lbs with my little belt tension gauge. Looking in the manual I noticed it says to do this with the riders weight on the bike. Well I am finding it a bit tough to sit on the bike and check the tension. I have always done it in the past without the weight.
My question is when you sit on the bike does the belt get looser or tighter ?? I am thinking and could be wrong that the arc of the swing arm with the pivot point bellow the trans pulley will cause the belt to loosen slightly as it swings up from weight ??
HD 95” HTCC heads,pistons,intake,
TW-5G Woods Cams
HRS 45, Crane HI4TC, Thunder Header
30 tooth tranny sprocket
3 Degree Raked HHI Tree
I am not responsible for my spelling grammar or intelligence, I am just a member
