2007 Softail dyno #'s Rush 2.0 *UPDATED*
Here is the before and after dyno sheet. The red lines are the stock baseline readings. The blue lines are with the addition of Rush 2.0 slip on mufflers. No other changes made. Note that the correction factor is STD.
The following sheet is the a/f ratio for the roll-on (closed loop) tests. Note that correction factor is STD.
The a/f ratio was virtually identical before and after the Rush muffler install.
2007 FXSTC, Cobalt Pearl/Pewter Pearl, Khrome Werks HP+ slip-ons, ISO grips & pegs.
Reason: update info
