Fab'd some motor mounts off my son in law's iron head. Used .125 steel plate. Same frame spacing as the chrome moly frame. Corresponding engine holes appear to measure the same with a vernier caliper as well.
Measured distance from lower front mount hole to rear evo mount 15-1/8.
Marked the frame. I can shorten the front mounts and relocate the engine forward as an option. Not sure yet.
Rear mount measures 9% incline from vertical. The diagonal brace tube that runs under the engine will interfere with the sump on the evo. I will have to cut it out and review other bracing options. Not sure if it is even needed as this is not a drag bike. Spoke with Dan Dunn (NRHS). Aaron Wilson runs a similar frame which didn't have the brace. I believe it was made for an evo motor. He went 169 at Bub's. I can cut the entire rear mount arrangement off and fab up a new one or chop this one and adapt to the evo.
