» Buyers Guides |
08-31-2008, 04:45 PM
Just another Hog Jocky
103, Big Boyz Heads, TW 6-6 Cams, TMAT
OK, not the most impressive numbers, but look at the torque those little Wood cams build! Over 100 FPT from 2,400 to over 4,600 RPM. This is a mild build, parts are listed in my signature. TB is stock and so are pipes except with Rush slip-ons with the left side restricted with a 3/4 inch washer. The difference between the first and last runs demonstrates how much a little timing change can effect performance. In this case we took two degrees away from it in the middle. Thanks Bean!, for a great set of heads at a reasonable price. So, what do you think good 2-1 exhaust would do for it?
My friends like me; everyone else thinks I'm an asshole. What's that say about my friends?
'07 Road Glide, 103 ci, Big Boyz "Bigger Valve" Street Port 85 cc heads, .030 quench for 10.2:1 cr, SE flat tops, Wood TW 6-6's, K&N air filter, Rush slip-ons, TMAT
08-31-2008, 04:54 PM
Average Dude
After only seven runs.....cool!! What did it put out when he was done tuning it??
Deut. 23:12-13
08-31-2008, 06:26 PM
Maybe a little more tuning time with what you have but with those cams and stock TB, save your $$ on buying more pipes.
MULTIPLE HARLEY RACE WINNER
8 TIME DYNO SHOOTOUT WINNER
08-31-2008, 07:46 PM
Gee Bob, do I detect a little sarcasm there? It was ALREADY tuned when I got there. The all-gear pull shows the AFR is dead on, and the only thing we did was take a little timing out, like I stated. This isn't a SERT where you have to make 20 or 30 pulls to get it tuned right. The point of the post is to show how good the cams are, not my tuning capability. Thank you. And thank you other guys for your comments, I think you are right on about the exhaust recommendations. I don't expect jaw dropping numbers from a build this mild, dependability and good fuel mileage were the aim.
08-31-2008, 07:59 PM
Nice looking torque curve.
04 GLIDE
95" 10.5 -1 S&S
TC-2G cams
RB Racing LSR 2 into 1
Ness Big Sucker
08-31-2008, 09:13 PM
I paid.........did you??
D&D Fatcat 2-1 with quiet baffle............my preferred exhaust system.
I have pretty much this same build only at 95" and it's great. Torque comes on early and the power stays on late..........I'm very happy with it.
I'm using the DTT auto-tune system, and with no tuning on my behalf it's running great and very strong.
Steve
09-01-2008, 03:39 PM
Thanks Maine, I know your bikes runs real good, I've been following as you have tried about every cam and exhaust in the book! I just can't get used to the look of that big fat Fat Cat hanging off the side, though.
04GLIDE: How do you like your RB LSR on your bagger? What's the noise level like at cruising? I had one on my '91 evo Softail, and I didn't find it too noisy at all, but I hear terrible stories from bagger owners. Mybe they are just too used to the quieter bikes with fairings and all?
09-01-2008, 03:50 PM
I love the RB pipe. It is only real loud when Im getting on it. On the freeway it's quiet. I love the sound of the pipe. Very throaty deep tone to it. I was running true duals with bassani slip-ons before. The wife say this pipe is much easier on her ears. She is back there right next to it most of the time. I regained alot of torque when I switched over to the RB pipe also.
04 GLIDE
95" 10.5 -1 S&S
TC-2G cams
Ness Big Sucker
09-01-2008, 03:56 PM
I know exactly what your talkin about
1982 SHOVEL - 96"
2002 FLHT STD
95" - 9.8:1 Comp
Wiseco Flattop Pistons w/ thermal barrier coating
Dewey's Pro Street Heads
Andrews 37G
Mikuni 42 Carb
Zippers adj. Ignition
LSR 2-1
09-01-2008, 05:09 PM
great looking bagger graph. i noticed the TMAT. its probably showing 13.2 afr flat line.
great way to get a nice highway tune with the TMAT, get timing straight and let the autotune get you to your desired afr. easy, efective.
you will notice a little better butt-meter after some miles. since you corrected timing, there are areas that TMAT will adjust fuel again.
also note------stock pipes, big torque line flat across. you may pick up some hp with true duals, you may pick up tq with 2-1, but you have a solid 103 that i bet runs really cool and you dont have to take it anywhere else----just ride!!
**************** disclaimer, yep, a good dyno man wih good software could tune in a couple hp/tq.
09-01-2008, 07:23 PM
I get a lot of compliments on the Fatcat, a lot of people have never seen it around here so they are always asking what it is and how cool it looks on there.
They make a ghost pipe for it too, that way you can have the 2 pipes out the rear for looks, and the great performance of the 2-1 system.
Steve
09-02-2008, 10:30 AM
Thanks again everyone, for your comments and input. Clyde: I am running 13.5 AFR in most RPM vs TBS positions except above 3,000 at 60 + TPS degrees I slope down to 12.9 for WOT performance, and 14.2 at light throttle cruise RPM's. Yes, the TMAT does a real good job of highway tuning and I get 44.5 MPG overall on 89 octane fuel. I only need to run premium when riding below 1,500 foot elevations in hot weather. And yes, it does run cool. I've never seen oil temp's over 225 in the hottest conditions with stop an go traffic. I do love this TMAT!
09-02-2008, 11:42 AM
Nice numbers MTNMOTORRIDER. Did you have to enlarge the valve reliefs in your flat tops for the bigger intake valves? Thanks
07' Night Train
103", S.E. Flat Tops,
Rev perform Heads
83cc/cnc ported
S.E. Cam Plate, Andrews 54H Cams
V & H Big Shots Long, PC lll
K & N, S.E. Clutch Spring
09-02-2008, 12:53 PM
mtnmotorrider, i thought we was pals till you called me clyde.
09-02-2008, 02:14 PM
Yeah, I just caught that too. I MENT to say "Clay", not Clyde! Sorry!!
Renagade: Yes, I did deepen and widen the intake relieves on the pistons just to make sure. With the zero piston deck height and larger valves, it would have been pretty close.
