Progressive Insurance
Pro Pad360 Brake CompanyTech N' Cycle GearRosa's CycleMotorcycle.com Classifieds!KomodoGear.comEagleRiderCrystal-GloAdvanstarMotorcycleShowsDaytona Twin-TecExtreme Custom EngravingAmericanMotorcyclistAssociationMetalArts
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > V-Twin Performance Forums > Drag Racing/Dyno Posting Forum
Old 08-09-2008, 05:33 PM   #1 (permalink)
HDMD88 will become famous soon enough
BWdiver 26A cam 96''
Posting this for DWdriver. Andrews 26A cam, stock 96'', TTS MasterTuner...tuned with V-Tune Program
Old 08-09-2008, 07:18 PM   #2 (permalink)
doc!! glad to see ya back. man those pipes killed it didnt they?
Old 08-09-2008, 07:19 PM   #3 (permalink)
Colorado crusin'
NewHawk's Avatar
NewHawk is on a distinguished road
Almost identical to mine.
07 FXDWG
SE A/C, K&N filter
Andrews 26h, D & D FatCat w/QB
NewHawk is offline   Reply With Quote
Old 08-09-2008, 07:55 PM   #4 (permalink)
BWdiver's Avatar
BWdiver is on a distinguished road
Thanks Doc!!! this thing runs great!!! I cant believe it!!!
BWdiver is offline   Reply With Quote
Old 08-09-2008, 10:21 PM   #5 (permalink)
Premium octane member
TXCHOP's Avatar
Doc, killer job as usually. BWdiver, you are a lucky man!
Great to see you post up Doc! Missed ya here..
HILLSIDE CYCLE 117
Hillside Cycle custom heads~S/E billet cam plate/oil pump~S/E 4.375 forged crank Darkhorsed~Axtell cyls and pistons~S+S p-rods and roller rockers~S/E CV51 carb~DTT ignition~Black Fatcat w/perf baffle~Pro Clutch~Woods TW9BG cams and KF325 filter
Old 09-09-2008, 01:33 PM   #6 (permalink)
BWdiver's Avatar
What would you recommend?
Old 09-09-2008, 02:31 PM   #7 (permalink)
splitting_lanes is on a distinguished road
what were the numbers?
I guess I should get a subscription, eh?
splitting_lanes is offline   Reply With Quote
Old 09-09-2008, 02:44 PM   #8 (permalink)
TXCHOP's Avatar
HILLSIDE CYCLE 117
Old 09-09-2008, 06:24 PM   #9 (permalink)
2-1 or factory headpipes with slip ons.
its obvious with a 26 cam you wanted early, quick hitting tq. the true duals killed the area the cams work best in.
common actually, most of the time because customer has already spent a grand on true duals and aint gonna change,but demands early tq, so we use the 26 to try and cover up the loss. then you run out of cam about the time the true duals decide to start working.
be happy doc was involved in the tuning, i bet yours in not quite so lazy getting on the pipe.
Old 09-09-2008, 08:47 PM   #10 (permalink)
01fxdx's Avatar
01fxdx is on a distinguished road
peak tork@3500, i'm used to shooting for 5500 for peak tork. not exactly the same goals i bet!!
01fxdx is offline   Reply With Quote
Old 09-09-2008, 08:54 PM   #11 (permalink)
BWdiver's Avatar
You know I'm happy with the build and tune Doc did, But I hate this tall gearing and the almost stalling feeling I get when taking off from a stop in which I heard is a combination of drive by wire and the gearing... what is the fix? take the tranny out and regear? I don't want a quik fix I want to do it right the first time.
I never had this feeling with my 03 flstf, maybe it's just me I don't know.
Thanks TXCHOP, for posting the chart...I need to join also!!!
Thank's guy's.
Old 09-09-2008, 09:17 PM   #12 (permalink)
01fxdx's Avatar
gearing is a tricky science. trial and error got me where i am happy now. not educated on the parts availability for the new 6 gear bikes, so i can't help. i think the sheet looks pretty good. be sure to hammer on it every chance you get!!
Old 09-09-2008, 09:35 PM   #13 (permalink)
Average Dude
YankeeBob's Avatar
Thank's guy's.
This may not work for your bike. You will have to check part numbers. But, take a look anyway.
http://www.v-twinforum.com/forums/tw...twin-cams.html
Deut. 23:12-13
Old 09-09-2008, 09:40 PM   #14 (permalink)
Iron Butt, SS2000
jerry34208's Avatar
BW all you have to do is give Doc a call. Ask about changing the primary ratio. As long as you have him on the line ask about the effects of swapping out the duals to a 2:1 D&D FatCat.
You'll be spinning the back tire by accident for the first month or so
Spare:
Old 09-09-2008, 10:15 PM   #15 (permalink)
Colorado crusin'
NewHawk's Avatar
Thank's guy's.
I have a very similar build and dyno sheet. I did mine in late Feb. very cool out. The first 4k miles (including a 3000 miler to OR) the bike ran great above 24/2500 (no tach) but taking off from a stop it seemed a little gutless. When I got back from my trip the first week of July the temps in ColoSprgs rose dramatically into the high ninetys and suddenly my bike would pop on decel unlike it ever had. I stopped by my tuner and caught him on a break, I told him what was up.
He had my map and added fuel to the 0 throttle position and reloaded it.
My sound went from a powerful hoarse (dry throat roar) in the higher rpms to a much more throated sound from 0 throttle. The response it gained in the lowest of rpm was a surprise. It didn't decel pop any more. My mileage didn't change. I don't know if I lost anything in the hp/tq that I got with the original tune, but if I did it wasn't much. I will probably go for a dyno run next summer from the same tuner in July just to see what is up. I am very happy with what I have. My tuner did a great job and I'm not knocking the tune you got, just relating what happened to me.
07 FXDWG
SE A/C, K&N filter
