Progressive Insurance
Motorcycle.comKomodoGear.comWheeldock.comCycleGear.comAmericanMotorcyclistAssociationMetalArtsSpringfield ArmoryMotorcycle.com Classifieds!Daytona Twin-TecRosa's CycleSportbikeTrackGear360 Brake CompanyMean City Cycles
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > V-Twin Performance Forums > Drag Racing/Dyno Posting Forum
SportbikeTrackGear
Old 07-29-2008, 03:37 PM   #1 (permalink)
towboattrash34 is on a distinguished road
Thumbs down My dyno results
well here is my dyno results... pretty lame so i will either get rid of Joe Mondello heads or try to have the reworked by someone else
93.87hp/93.05tq
06 Dyna Lowrider
95 build W/GMR Welded Heads
SEII's w/stage1 and SERT
J&E pistons
Woods TW-7H cams
Built by me.
towboattrash34 is offline   Reply With Quote
Old 07-29-2008, 03:43 PM   #2 (permalink)
Premium octane member
TXCHOP's Avatar
Jeff. Did the tuner really only spend 40 minutes and 5 runs tuning a your fuel injected bike. Not knocking anyone, just wait on pulling it down to see what other think. I think you have at least a few more tq hiding in there.
HILLSIDE CYCLE 117
Hillside Cycle custom heads~S/E billet cam plate/oil pump~S/E 4.375 forged crank Darkhorsed~Axtell cyls and pistons~S+S p-rods and roller rockers~S/E CV51 carb~DTT ignition~Black Fatcat w/perf baffle~Pro Clutch~Woods TW9BG cams and KF325 filter
Old 07-29-2008, 03:54 PM   #3 (permalink)
FXDRYDR is on a distinguished road
What TX said. A thorough tuner will do a lot more runs than that. I have to think there's plenty left on the table.
FXDRYDR
2003 FXD
98" Small Bore
107HP/113TQ
FXDRYDR is offline   Reply With Quote
Old 07-29-2008, 03:55 PM   #4 (permalink)
may not be as bad. the new trannys dont allow the numbers 5 speeds do, couple that with SAE, maybe a lazy dyno----------curve looks like good tq across the board.
oh, and wut they said about the 5 run tune.
will it wheelie?
Old 07-29-2008, 03:58 PM   #5 (permalink)
Moneygreen
arealinvestor is an unknown quantity at this point
Dude!!!!!!! what do you expect from a 95CI motor????? with a great tune you might have maybe 7 or 8 more hp in that motor!!!!!! You will be lucky if you break 100hp,and i do mean lucky.Your running SE heads? did i read that right? Did anyone ever tell you CI mean everything???????especially when it comes to HP/TQ
Craig G.
Old 07-29-2008, 05:39 PM   #6 (permalink)
Lucky Man
BVBOB's Avatar
I take it by your thumbs down that you were led to believe it would make better numbers than that, more info on you build if you don't mind, headwork?, compression, tuning device?
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
2006 Streetbob
HQ 575 cams
Heads street port 1.9 valves
98" bored stock cylinders with JE pistons
D&D Fatcat SE Heavy Breather A/C
Every man dies, but not every man lives!!!
Old 07-29-2008, 06:08 PM   #7 (permalink)
The story of my life!
ceraaa42's Avatar
So how does it ride? That is a nice looking tq curve, even for just 5 pulls.
Are you using the SERT? If so, I'd suspect they just set the fuel at wide open and that's it. No timing work, no trial and error, nothing ,or the pulls would be there.
I proper tune will net more power I'm sure, but don't get hung up on the numbers.
My first build was similar to yours and the also the numbers. It ran so good and the power was there, I was afraid to mess with it or it might not run as well.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
ceraaa42 is online now   Reply With Quote
Old 07-29-2008, 06:36 PM   #8 (permalink)
Mondello heads are supposed to be top of the pile. I can't open the graph but what pipes are you running. And as others have said could be a stingy dyno. Did you check the tire air pressure and was the operator sitting on the bike or standing beside it. Lots of varibles.
Old 07-30-2008, 04:51 AM   #9 (permalink)
even with a bad tune they did get 10 more out of it...heck it did feel stronger before the tune now it feels week... the heads are 1.940/1.570 89cc's 10.5.1 comp w/JE 10.25.1 pistons.... the heads are killing the cam... Joe and Bob woods said it should be getting about 107 on the tq..... i seen several dyno sheets at another dyno shop with just a 95 kit and no head work with just a cam making more than me...... for 5,100.00 you kinda expect your money worth.....so yea i'm a little pissed. i'm not going to chase this down with putting diff cams in,what i am going to do is get a diff set of heads/good 2> pipes or have mine reworked by someone that knows motor bikes then i will pay for a good tune not like the 1 i got going to cost 400.00/Joe knows cars not bikes... he should of known what works it was his package and heads.
06 Dyna Lowrider
J&E pistons
Woods TW-7H cams
Built by me.
Old 07-30-2008, 05:02 AM   #10 (permalink)
tuned with a sert... the master tunner is off hurt with 4 broke ribs so my builder which is not the tunner did my tune/he is a very good builder and recomend him to anyone,but he did do the best he knew how.. i have another tunner inline for the next tune that comes highly recomended and i went to talk with him and he took his time and showed me everything about it and let me help him on the dyno and said it takes him about 5hrs or more for a tune and will give me the map also, so i will pay him 400 he charges for a good tune after i get a new set of heads and pipes
06 Dyna Lowrider
J&E pistons
Woods TW-7H cams
Built by me.
Old 07-30-2008, 05:38 PM   #11 (permalink)
Lucky Man
BVBOB's Avatar
Dont scrap everything at once, first try a set of pipes, the fatcats fit nice and work well on my 06 Dyna, I don't think you are all that far off, a better pipe and a little timing work can go a long way toward getting what you are after.
2007 Ultra
Woods 7H cams
D&D Fatcat, SE/AC
2006 Streetbob
HQ 575 cams
Old 07-30-2008, 06:17 PM   #12 (permalink)
AMEN. folks dont wanna blame shitty pipes----they paid so damned much for em. recently, i saw 4 tq on 1 degree timing change, and it was right in the meat of the curve!
Old 07-30-2008, 10:39 PM   #13 (permalink)
C-Cat is on a distinguished road
more or less timing for the 4lbs. change in torque?
C-Cat is offline   Reply With Quote
Old 07-31-2008, 04:40 AM   #14 (permalink)
yes i will get a 2>1 pipes... the way the heads are built the se 257 cams would work great because of the 1.570 exhaust valve and the 260 duration on the exahust side of that cam,but i recon why i'm bitching is i payed for a woods cam build not a se build...
sorry for the rant......but even like it is with a good tune and 2>1 pipes the heads are still going to hold the cam back and i just can't see spending 400 on a tune then still having to redo it and then pay for another tune which is what Joe wants me to do....not happing when i payed him for heads to work with that cam
06 Dyna Lowrider
J&E pistons
Woods TW-7H cams
Built by me.
Old 07-31-2008, 05:03 AM   #15 (permalink)
3,250 just in parts/95 kit with port/polish/new valves/decked/cc'd/comp releses everything...including the cams bob woods springs.
06 Dyna Lowrider
J&E pistons
Woods TW-7H cams
Built by me.
