Tote, could you explain a little more what's taking place with a softail that causes it to soak up more power on a dyno. I get the initial launch at the strip being softened by energy being transfered and dispersed by the shocks but after the initial hit when the suspension becomes more or less static (more so on a dyno) why would the suspension continue to soak up HP? I mean, at that point you have a belt turning an axle that is stationary in either case so what would be the difference?
Perhaps some part of each power pulse is moving the suspension and therefore being dampened? But wouldn't how much is absorbed simply be a function of how soft the suspension is set rather than what type of suspension is used?
Thanks, Tote.
