When I had my Stage 1 88" dynoed, it showed 72hp and 78tq. That was with Rinehart True Duals, Ness Big Sucker, and a PCIIIusb with my stock 88" motor.
Numbers are hard to go by alone, every dyno reads different, so what you think you should be getting compared to what you are showing on the dyno could be the samething, but the numbers will fool you.
Adding just cams to a 88" motor will not make a huge night/day difference, it will move the powerband a bit, but won't blow your socks off. The compression in a stock 88" is too low to make most cams work well and the heads don't flow as good as they could.
Steve
