Progressive Insurance
CheapCycleParts.com360 Brake CompanyAdvanstarMotorcycleShowsOriginalBikeSpirits.comPro PadRosa's CycleDaytona Twin-TecProCharger.comTech N' Cycle GearArnottAirRideAmericanMotorcyclistAssociationSportbikeTrackGear
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > V-Twin Performance Forums > Drag Racing/Dyno Posting Forum
ProCharger.com
Old 04-01-2008, 06:01 PM   #1 (permalink)
Dazed and confused
stretch
107" Build Done !!!
I got my bike back from JD's over the weekend and it runs more than great. Its super smooth and pulls really hard. Highway cruising from 55-85 mph in 6th is a breeze. Its what the bike should be stock but that's just my opinion. Specs are SE 103" crank, Axtell 107" cylinders with compression set for 10.5:1, Baisley "Super Stock" ported heads, ThunderMax/Autotune MM conversion w/50 mm TB and a custom basemap from JD's, Woods TW6HG cams, D&D Fatcat w/quiet baffle. Here's the dyno sheets, I think they are pretty damn good !
2000 Ultra Classic
JD's Cycle Works built 107", Baisley Ported heads, Axtell cylinders, TW6HG, Thundermax w/Autotune, 2-1 D&D FatCat, Baker DD6 120 hp/122 torque (uncorrected) 113/116 SAE
stretch is offline   Reply With Quote
Old 04-01-2008, 11:02 PM   #2 (permalink)
gofastflhx is on a distinguished road
do you know what your cold cranking compression is
THE GREATEST JOY IN LIFE COMES
FROM THE PEOPLE WE LOVE
gofastflhx is offline   Reply With Quote
Old 04-02-2008, 07:56 PM   #3 (permalink)
Dazed and confused
stretch
Its right at 200 psi. I do have compression releases but it will fire up without it when I forget to use them.
2000 Ultra Classic
Old 04-02-2008, 08:05 PM   #4 (permalink)
Dazed and confused
stretch
Originally Posted by SEDELUXE View Post
looks like a fun ride ......
Tks G !
It is especially for a bagger but I'm guessing its a dog compared to your 'little' scooter. I rode Dave's RK with the 120" and it will do damage to your shoulder sockets, I can only imagine what a more potent package on an even lighter bike will do !!!
2000 Ultra Classic
Old 04-03-2008, 05:24 AM   #5 (permalink)
Dazed and confused
stretch
Will do !
2000 Ultra Classic
Old 04-03-2008, 08:48 AM   #6 (permalink)
Premium octane member
TXCHOP's Avatar
Congrats on the build Stretch! Looks like that will eat some tires for sure!
HILLSIDE CYCLE 117
Hillside Cycle custom heads~S/E billet cam plate/oil pump~S/E 4.375 forged crank Darkhorsed~Axtell cyls and pistons~S+S p-rods and roller rockers~S/E CV51 carb~DTT ignition~Black Fatcat w/perf baffle~Pro Clutch~Woods TW9BG cams and KF325 filter
Old 04-03-2008, 05:44 PM   #7 (permalink)
Doofhead
by the way, the HP flattening out above 5200 rpm is indicative of a limitation or restriction on the intake side or the fuel pressure regulator hasn't been modified yet to increase the supply pressure. If I could see the AFR chart, we could see if it's going too lean on the top end or not.
Bottom line is..... there is more in there.
'05 FLSTCI - Cobalt Blue w/ Candy Flames [custom paint by VonRaknid]
Chubby WO515 Bars - 18" Fat Daddy 50's w/ ME880's - GMA Brakes - Baker DD6 - 95" w/ SE Cast Flat Tops - Street Ported Heads 9.9:1 CR - [Engines by Otto] - Andrews 37G - 1.675:1 Rockers - Dakota Kid Delphi TB/Intake - SERT tuned by Otto - RB Racing LSR 2:1 - 96hp/106tq
Totenkopf is offline   Reply With Quote
Old 04-03-2008, 07:01 PM   #8 (permalink)
Dazed and confused
stretch
That may be true but since its an "autotune' we figured to let it get a few more miles on it then play with the base map some more as needed but it does run great, no bad habits at all. Probably after I get a 1-2k on it, we'll run it again on the dyno and see what the 'Autotune' accomplished or disturbed.
2000 Ultra Classic
Old 04-03-2008, 07:19 PM   #9 (permalink)
Doofhead
has your regulator been modified to increase fuel pressure?
Old 04-03-2008, 07:51 PM   #10 (permalink)
Dazed and confused
stretch
Its a Thundermax 50 mm throttle body (MM conversion). I would have to say no but not sure if its even possible.
2000 Ultra Classic
Old 04-03-2008, 08:16 PM   #11 (permalink)
"I'm Jack & I'm TIRED..."
ChromeWelder's Avatar
Location: Denver..Inner City...East of 43 tracks..(between Arby's and Jiffy Lube)
ChromeWelder is on a distinguished road
Wow! That build runs! ..."I wish I had a horse that could do that..."
Enjoy and ride SAFE!
2006 Road King Classic...
95" 1.7 Million Whorse Power / 2.3 Billion Pounds of Torek...
BOZO the Clown 1915-2008 RIP
ChromeWelder is offline   Reply With Quote
Old 04-03-2008, 08:43 PM   #12 (permalink)
Doofhead
I can't tell from the T-Max sales blurb info but on regular MM efi systems, they are notorious for having low fuel pressure that can limit the engine output in the upper band.
for example, on a true MM system, here is a link to a aftermarket boosted pressure regulator....
http://www.dakotakidcarbs.com/magneti.html
Old 04-03-2008, 08:43 PM   #13 (permalink)
Vendor
jdscycle is on a distinguished road
107
Tote, I agree that the dyno sheets show a restriction. But you have to remember that we are running a Quiet baffle on this bike.I would like to slip on a performance baffle on the next visit to determine if this is the case.If so, we will post the differences in the torque curve between the two mufflers.
I also believe that the numbers are a bit askew due to the Baker DD6 trans.
Dave
jdscycle is offline   Reply With Quote
Old 04-03-2008, 08:47 PM   #14 (permalink)
TXCHOP's Avatar
I agree Dave. I have seen the Baker take at least 4/4 from a build. I guess it's just friciton and mass of spinnin another extra gear.
HILLSIDE CYCLE 117
Old 04-03-2008, 09:21 PM   #15 (permalink)
ToBeFrank's Avatar
ToBeFrank is on a distinguished road
No need if you're just going to dyno it at WOT. Take it out, make sure it's fully warmed up, do 3 WOT runs in third gear from 2000 rpm to redline. You'll be fully dialed in at WOT.
ToBeFrank is offline   Reply With Quote
