» Buyers Guides |
03-29-2008, 11:43 PM
Dyno numbers for 3:37 and 3.17 which would be higher
Guys is there a diffrence on the dyno with these two diffrent gears
THE GREATEST JOY IN LIFE COMES
FROM THE PEOPLE WE LOVE
03-30-2008, 06:49 AM
Average Dude
I know there is to the pavement!!
Deut. 23:12-13
03-30-2008, 08:24 AM
Gearing
The 3.37 will certainly rev quicker, but the 3.17 ratio, will show a higher hp and torque number on the dyno.
Palmer Bros.
Hillside Motorcycle & Machine
V-Twin Performance Center
Munnsville, N.Y.
315-495-6650
www.hillsidecycle.com
"Repairing Broken Torque Curves Since 1982"
Land Speed Record Power
03-30-2008, 11:28 AM
will the newer bikes (07-08's) with the higher gear ratio dyno more or less hp and tq then the 3.17 gears?
03-31-2008, 11:38 PM
The dyno operator should set the ratio as part of the "constants" before calculating tq and hp--the engine isn't doing anything differently regardless of the gear ratio so the numbers should be the same.
CMA, Crossties Chapter (GA)
IBA 26580
2004 FLHTPX
05-15-2008, 07:37 PM
Are we having FUN yet?
American Bagger did a test of these, the dyno showed the same curve and output, Torque and Horsepower.
But it gets it to the ground easier.
I'm Just Sayin'...
2007 FLHT 96 CID W/IDS drive
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
93.25 Torque 78.74 HP
Professional Rockat Surgen
Disclaimer.
05-15-2008, 08:01 PM
this is a really good thread actually. what gearing produces the best brag sheet?
when actually it doesnt mater-----------the dyno oerator looks at the curve and knows what he need to do.an old dyno rule is dont pick the gear that shows the best numbers, pick the gear based on tire and drum speed.
think about that one!!!!!!!!!!!!!!!!!!!!!
05-15-2008, 08:28 PM
The story of my life!
So, my question would be, do the hp/tq curves change with the different gears?
Just the curve not the numbers.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
05-15-2008, 09:01 PM
on dynos i am familiar with, curve will remain the same, numbers will change.
05-15-2008, 09:46 PM
Premium octane member
How bout picking a longer gear for a better(longer) sampling rate of AFR?
HILLSIDE CYCLE 117
Hillside Cycle custom heads~S/E billet cam plate/oil pump~S/E 4.375 forged crank Darkhorsed~Axtell cyls and pistons~S+S p-rods and roller rockers~S/E CV51 carb~DTT ignition~Black Fatcat w/perf baffle~Pro Clutch~Woods TW9BG cams and KF325 filter
05-15-2008, 10:31 PM
that has been said many times, but in the dyno directions, it says choose a gear that doesnt allow the tire speed to go past its rating, and doesnt overrev the dyno drum.
