Melted Battery Post : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Model Specific Discussion Forums > Choppers and Customs
Old 11-29-2012, 07:18 PM   #1 (permalink)
110Hardcore's Avatar
110Hardcore wants to know Dino or Syn?
Melted Battery Post
A little background first...
Bought a Hardcore II in October, replaced ignition switch, replaced Headlight, replaced marker/turn lights with LEDs. Had to track down wires in harness that were never connected originally to make most of it work. Bike runs fine, with a RevTech 110 (1800cc), 6-speed.
Problem:
Ran around town a little today, got home and shut it off to open garage. Would not start. Removed seat found positive post melted a bit. Battery was rated at 310 CCA. Did a parasitic check for drainage with none found.
Seen a melted post before on a car but don't remember the cause. Am thinking the starter pulled too many amps to cause the melt. But do not know the solution other than a larger CCA rating, if that is the problem
Any help?
110Hardcore is offline   Reply With Quote Quick reply to this message
Old 11-29-2012, 07:25 PM   #2 (permalink)
I'm Paid Up...
DR_DEUCE wants to know Dino or Syn?
Most likely it is the result of a poor or loose connection at that terminal.
DR_DEUCE is offline   Reply With Quote Quick reply to this message
Old 11-29-2012, 09:00 PM   #3 (permalink)
not sober all the time
Uncle Salty is reading this now saying WTF is this? Uncle Salty is reading this now saying WTF is this?
That would be my first bet.
Uncle Salty is offline   Reply With Quote Quick reply to this message
Old 11-29-2012, 09:19 PM   #4 (permalink)
jammer45u's Avatar
jammer45u is reading this now saying WTF is this? jammer45u is reading this now saying WTF is this?
plus two. Loose connection.
jammer45u is offline   Reply With Quote Quick reply to this message
Old 11-29-2012, 09:26 PM   #5 (permalink)
Rollmeaway's Avatar
Rollmeaway wants to know Dino or Syn?
All good points made, excessive resisitance at the battery positive+ terminal due to a bad/loose connection. Starter pulling too many amps & melted the teminal.
There is no greater draw in the average electrical circuit than the starter. If it has for one reason or another lost or has a reduced ground circuit due to corrosion the starter when called upon will easily draw up to 3 times its normal amperage. It will seek a ground if it has to do it from within itself.
If not the Posi terminal at least check the ground connection to the frame/starter.
If you have troubles starting it again you could run a heavy ground cable to the starter from the battery. A way of checking it is take your neg (black) booster cable, attach one end to the starter housing & the other to the battery ground terminal to see if it alleviates the problem
We never even said a word,
And we rolled...
Dare...
2000 FXST - Carbed
Rollmeaway is offline   Reply With Quote Quick reply to this message
Old 11-30-2012, 04:43 AM   #6 (permalink)
tussuck's Avatar
tussuck wants to know Dino or Syn?
+3 on a loose connection
Sent from my iPhone using Motorcycle.com App
I prefer my engine blown not stroked!
D.L.R.A #1174
tussuck is offline   Reply With Quote Quick reply to this message
Old 11-30-2012, 05:19 PM   #7 (permalink)
Thanks for the assistance. It was a loose connection (although it seemed tight). Going to replace the cables anyway, as I do not like them, they look kinda cheesy and cheap. Battery getting good charge up tonight, will take it to the Zone or someplace and see if it checks out.
Old 12-02-2012, 01:07 PM   #8 (permalink)
Johne wants to know Dino or Syn?
How many cranking amps are you pulling for that 110? I'm thinkin about putting a 124" in when my 80" dies. I just curious to how much cranking amps I will need to run.
Johne is offline   Reply With Quote Quick reply to this message
Old 12-03-2012, 07:00 PM   #9 (permalink)
Couldn't say... Know that it had a 310 CCA battery in it. Seemed to start okay until I melted the post. Going to a 600 CCA Lithium from Antigravity Batteries (antigravitybatteries.com). A little expensive, but the stats look good and they aren't made in China. The battery physical size is about an inch smaller in height and length.
