When My 80" dies I'm Thinkin 124" : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > General Discussion Forums > Choppers and Customs General Discussion
Old 12-02-2012, 12:17 PM   #1 (permalink)
Johne is on a distinguished road
How much cranking amps will I need to start it? S&S has an exact fit so they say for my 92' FXSTC.
Johne is offline   Reply With Quote
Old 12-02-2012, 01:06 PM   #2 (permalink)
gb1500 is on a distinguished road
when my 80" dies im gonna rebuild it....seems like it has enough power now for what i need it for and its never let me down
gb1500 is offline   Reply With Quote
Old 12-02-2012, 05:17 PM   #3 (permalink)
I'm a power speed junky. I want it there when I feel the need for speed. Otherwise, the 80" has been great to get me to work and local rides. Now that the speed limits are higher, so should my horses!
Old 12-03-2012, 04:43 AM   #4 (permalink)
Merc63 is on a distinguished road
Your stock starter might be ok, if not a after market one. I use a terry components 1.8 kw.
Merc63 is offline   Reply With Quote
Old 12-03-2012, 06:04 AM   #5 (permalink)
lonslo is on a distinguished road
If you wait till it dies it will probably have 300k or so miles. By then you will probably want a 150 or bigger.
lonslo is offline   Reply With Quote
Old 12-03-2012, 10:31 AM   #6 (permalink)
S&S Cycle's Avatar
S&S Cycle is on a distinguished road
Use the Stock H-D starter
We recommend using the Stock H-D starter, and make sure you use a chassis ground and a ground wire that is connected directly to the starter.
You should not have issues with that combination with a 124"
Thanks,
S&S Cycle, Inc. Performance Motorcycle Parts for American V-Twins
http://www.sscycle.com
https://www.facebook.com/SScycle
866-244-2673
S&S Cycle is offline   Reply With Quote
Old 12-04-2012, 09:48 PM   #7 (permalink)
You folks at S&S must have telepathy! I was going to call you today but got crazy busy at work! I will be calling for some other ideas for the complete project. I have decided to keep the 80" as it is because it is for the most part, all original. @lonslo, your right, I plan to max out this ride to see if I can keep it alive for that many miles and more! Right now, 89,000 and running strong.
Old 12-04-2012, 09:53 PM   #8 (permalink)
Thanks Merc63. I think I will be starting from scratch so I will be considering all options that will be the best for what I have planned.
Old 12-05-2012, 01:17 AM   #9 (permalink)
I think I'm done considering. If the 80" gives up, I'm going with a 96" and putting the 124" in set up that will handle the power. More than likely a pro street.
