Custom DynamicsMotorcycle-CommunicationFuel MotoBub EnterprisesDiamond Bar ChoppersRRcycles.comDan Vance Racing
SportbikeTrackGearCycleGear.comMBO Enterprises
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > General Discussion Forums > Choppers and Customs General Discussion
Old 06-13-2009, 07:09 PM   #1 (permalink)
BCer is on a distinguished road
Clutch adjustment
Hello;
I have a primo 3 inch belt system. BDL non adjusting clutch lever.
Open primary.
I have not rode the bike in 4 and a half years.
The adjustment was good and now I cannot shift down in gears.
I adjusted a couple of times, no luck.
I pulled the clutches and steel plates out of the basket and cleaned them, I did a light sanding on the friction discs and readjusted, hard upshifting and still no down shifting.
Need help , thanks.
BCer is offline   Reply With Quote
Old 07-02-2009, 01:32 AM   #2 (permalink)
hbmc's Avatar
you may want to try the manufacturer for a trouble shoot as I do not know how you get clutch adjustment with a non adjusting lever? definitely sounds like adjustment I noticed you had 66 looks and no response may also move this thread to tranny and Primary?
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
