AdvanstarMotorcycleShowsMotorcycle.com Classifieds!RRcycles.comJardineProducts.comDan Vance Racing
CycleGear.comSportbikeTrackGearCustom DynamicsPro PadMBO Enterprises
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > General Discussion Forums > Choppers and Customs General Discussion
Old 04-25-2009, 05:54 PM   #1 (permalink)
rccsr is on a distinguished road
revtech 110 low oil light
I need some help from one of you on here. I have a brand new chopper that I built and put a 110" revtech in it. I have a dakota digital dash that has a low oil indicator message.
When I start the motor the low oil message goes away. The bike runs good, although it idles a bit low (i'm working on that). The bike runs well while riding. After a significant run, if I come to a stop sign or light the low oil indicator comes on. It will flash on and off as I come to a stop or at really low rpms. This only seems to happen when the motor is hot.
There is enough oil in the oil tank. The oil lines are routed properly (to their correct location, no kinks,3/8" hoses). I do not have any breather hooked up as of now. The oil tank is not vented to atmosphere. The oil level is below both the vent and return nipples. The oil feed to the motor is located at the lowest point of the oil tank.
Any ideas? Thanks.
rccsr is offline   Reply With Quote
Old 04-25-2009, 07:20 PM   #2 (permalink)
screw a gauge into it to be sure.
Old 04-25-2009, 10:14 PM   #3 (permalink)
bwana01's Avatar
bwana01 is on a distinguished road
it is quite normal for that motor, when hot and in idle, to only be making 5 - 10 pounds on an oil pr guage. That is why you are getting the flickering light on the Dakota Dig.
bwana01 is offline   Reply With Quote
Old 04-25-2009, 10:35 PM   #4 (permalink)
FLHtoFXD's Avatar
FLHtoFXD is on a distinguished road
idle
Probably a good idea to get that idle up a bit and all will be good.
2004 Superglide
95 inch 10.5-1 JE pistons
Branch #4 heads with compression releases
Andrews T55G gear drive cams
Jims roller rockers
Feuling superpump and lifters
DTT TC88A ignition
Mikuni HSR45 carb with 3 inch filter
S.E. adjustable pushrods and tubes
S.E. high tensile cylinder studs
Barnett scorpion clutch
S.E. 2-1 pro pipe with home made baffle
Progressive fork springs and 11 inch black 412's
Sputhe Positrac
Vulcan Mid-glide trees
Headwinds carbon fiber headlight
FLHtoFXD is offline   Reply With Quote
Old 04-26-2009, 09:22 PM   #5 (permalink)
Thanks for the suggestions.
I'll get the idle up a bit. I did, however, find that all of the oil line fittings were 3/8" except for the three in the oil tank which were all 5/16" 1/8npt. Do you guys think it's worth switching them to 3/8"?
Thanks again.
Old 04-26-2009, 09:40 PM   #6 (permalink)
strokerjlk's Avatar
my R/T would do the same if not idleing 1000 rpm.
still was loooow 3-5 lbs when hot
good luck
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
