Tom:
I run a P&P on my chop, you are correct, the axle that came with them was 5/8ths, with "turned down ends" What I did was have another axle made that is 3/4 so I could run a narrow glide 19 inch mag. Also, you are correct, you have to take one leg off to put the axle in. Do yourself a favor, use a ratchet strap between the two "tubes" that the leg shafts run through, BEFORE you take a leg off. (don't ask me how I know this, I just do) I use one of the shipping straps that come on a new HD, you can get them at the dealer for a couple bucks.
Hope this helps.
p.s., how long is the girder? mine is 6 over.
