» Buyers Guides |
08-27-2007, 11:19 AM
starting help
All done with the new build and now it won't fire.
Evo engine, 5-speed kickstart, S+S super E carb, ultima ignition and coils.
It has spark and compression. Looks to be ruffly timed correctly in that the spark and compression coincide. Mostly I get a single pop when its kicked. Once in a while it will give three or four sputers.
Any suggestions on where to look fo the problem? THanks.
08-29-2007, 02:17 PM
Are the plugs wet or dry after a few attempts? Sounds like fuel ( or lack of ) may be the problem. I would also double check the intake manifold for air leaks where they bolt to the heads.
" Ya bitch about the present, Ya blame it on the past, I'd like to find your inner child and kick its little a$$, Get over it! " The Eagles
08-30-2007, 11:17 AM
After a few attempts the plugs are 90% wet, with the end of the strap and a little of the center electrode dry. The plug gets sooty black on half and stays clean on the other half.
08-30-2007, 02:15 PM
Well the ign you are using is not set up for kick start, so if you get very lucky you might get it to start. You need a ign system that does not need 2-3 revolutions to fire.
We just built a S&S 96 crate, kicker only, The ign with S&S is able to be put into kicker mode, same deal we had to then install a stroker kicker on it as we needed just a tad more OMPH to roll it over. Starts now on 3-4 kicks cold.
08-30-2007, 04:14 PM
The ignition has a kick or electric setting. Sure would love to get it to start cold on 2-3 kicks, sounds like a perfect build.
08-30-2007, 04:19 PM
HMM I was not aware that the ultima had that option so that is good, now what plug gap are you running, and are you using a spacer from intake to carb. What it the intermidate jet is in the carb, float level need to be checked.
With a kicker the jetting timing, etc needs to be spot on. If we can get a 10.5.1 96 stroker to start with a kicker than you can get that 80 inch going.
09-05-2007, 05:36 PM
Plug gap is .039
Intermediate jet is .028
No spacer just the 1/4" insulator block
09-07-2007, 11:38 AM
try gap at 35 and a stroker kicker
09-10-2007, 11:46 AM
Valve
Pushrod adjustment ok?
Palmer Bros.
Hillside Motorcycle & Machine
V-Twin Performance Center
Munnsville, N.Y.
315-495-6650
www.hillsidecycle.com
"Repairing Broken Torque Curves Since 1982"
Land Speed Record Power
09-19-2007, 01:31 PM
Finaly got it to fire. After a min or so of idleing some very foamy oil started to come out of the breather hose. Whats that mean? Thanks.
09-21-2007, 11:52 AM
Well you may have a leaking check ball , and the oil was allowed to fill the crank case. With a kicker a crank case that has excessive oil would be hard to start.
05-04-2008, 10:28 PM
Foamy oil,  Also make sure your return line and vent line are not crossed to the oil tank. Ignition timing is critical.
