There are a few things that you can check Woody.First make sure that your throttle cable is not so tight that it is pushing on the plunger.You could also have dirt or a tear in the diaphragm on the bottom of the plunger.It is in the little disc like part of your carb on the bottom.This acts like a check valve and you may be getting flow through it from your bowl.The natural flow of air by the nozzle will act like a syphon,similar to sucking on a hose to siphon from one container to another,once it starts it won't stop.Try shutting the petcock also,the fuel is trying to maintain the same level that is in the tank.Good luck,Ron
