Remove gas cap & look in yer tank, that will tell how it is.
HD has been coating tanks since approx 1991 IIRC ? Their coating is usually no problems.
A quik drain of fuel & pull petcock for inspection is about due IMO..
Then you can proceed from there.. If you are gonna remove the carb, I would also replace the gas line, while you are there..
Bud
