Progressive Insurance
Mean City CyclesSpringfield ArmoryStoneyStraps.comAdvanstarMotorcycleShowsEagleRiderTech N' Cycle GearProCharger.comExtreme Custom EngravingBikeBandit
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Fuel Systems > Carb Discussions
ArnottAirRide
Old 06-29-2008, 11:46 PM   #1 (permalink)
wampuscat is on a distinguished road
Angry Broke fuel hose connection
Yes, I'm a dumb-ass! I broke the plastic 90 degree fuel line connector at the carb. This is a stock HD carb on a '94 Evo. It broke at the point where the plastic meets the brass, so the connector hasn't damaged the carb body. Is this a part I can replace from the local auto parts store? Or am I screwed into waiting for the nearest shop to order it?
Next question: Does this connector screw in or press in? If it screws in, is it right or left hand threads?
Yes I do have the HD manual, but it doesn't say anything about this dumb-assed mistake.
wampuscat is offline   Reply With Quote
Old 06-30-2008, 12:04 AM   #2 (permalink)
Premium octane member
TXCHOP's Avatar
Its a press in fitting(light press). A pair of vice grips and some wiggling usually take them out. Most dealers do carry them in stock as its a somewhat common thing to break. If they give you a choice, go with the newer design all brass fitting.
HILLSIDE CYCLE 117
Hillside Cycle custom heads~S/E billet cam plate/oil pump~S/E 4.375 forged crank Darkhorsed~Axtell cyls and pistons~S+S p-rods and roller rockers~S/E CV51 carb~DTT ignition~Black Fatcat w/perf baffle~Pro Clutch~Woods TW9BG cams and KF325 filter
Old 06-30-2008, 12:26 AM   #3 (permalink)
Pebble Cruncher
Rockbiter's Avatar
Rockbiter is on a distinguished road
Check out Dakota Kid Carbs, they have the brass 90deg fitting, and a few other goodies (I love the thumbscrew idle mix screw)
presses right in, cake to replace.
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote
Old 06-30-2008, 12:59 AM   #4 (permalink)
Lightbulb Now, getting it in?
OK I got the fuel 90 out without any problems. Used a self-tapping screw and pliers, worked with even tension and it came right out. Now when I get a new connector, whats the recommended way to install it and avoid a return trip for another one?
I'm still wondering if I can get one at an auto parts house? It looks to be 8mm by eyeball measurement. I knew there was a reason smart people had calipers.
Old 06-30-2008, 02:11 PM   #5 (permalink)
Talking Answering myself
No way for the local auto parts fix... They do have a threaded 90 but no press in 90. JP Cycles has the old plastic POS for $10 if I want to wait, nope. 50 mile round trip to the nearest HD dealership that recently started opening Mondays and $13 later, I have a new brass 90.
Now for the install: tap it in...hell no. I used a 4" C-clamp and a 1" wooden paint brush. I put the brush against the carb body to give even pressure. Don't wanna break the carb also now do we?
