Spitting back through the carb : V-Twin Forum: Harley Davidson Forums
Old 05-11-2011, 08:22 AM   #1 (permalink)
engrguy wants to know Dino or Syn?
I have a 05 electra gluide and it has spit back threw the carb since it was new. It does it when you are crusing at a steady speed. It has gotten worse and more frequent as it has gotten older any suggestions?
By the way I have upgraded to a big bore kit and a woods 6h cam.
I have a SE 44 mm carb that I ran on my evolution I could clean up and get a manifold for and put on
engrguy is offline   Reply With Quote Quick reply to this message
Old 05-12-2011, 07:18 PM   #2 (permalink)
dunbarton wants to know Dino or Syn?
carb sounds lean.
what jets and needle?
it's an oem cv40 now right?
did you re-jet when 95'd and cams replaced?
dunbarton is offline   Reply With Quote Quick reply to this message
Old 05-13-2011, 10:23 AM   #3 (permalink)
Yes it is the originall oem cv40. But it has ALWAYS done this. I know when a carb is lean they will spit back. Also when I went to the 95 kit I did re-jet it to a 195? Does that sound right?
What do think about the SE 44 I have?
Old 05-14-2011, 06:28 PM   #4 (permalink)
Mtclassic wants to know Dino or Syn?
If it is spitting back while steady cruise I would raise your needle .04-.05 or so. Maybe go up one size on slow jet and make sure your air fuel screw is adjusted properly. It is very popular to replace the stock needle with a N65C needle (early per acc. pump sportster needle) also check for intake leaks after a while the seals around the manifold could be leaking causing a lean issue. I put over 80,000 miles on my 04 carb and it still looked good when I pulled it apart so unless you have really high miles I would not worry about it being worn out. The 44 would probably be a good match for you cams.
Mtclassic is offline   Reply With Quote Quick reply to this message
