Super E accelerator pump question : V-Twin Forum: Harley Davidson Forums
Old 04-16-2011, 08:08 PM   #1 (permalink)
Big_Cheese wants to know Dino or Syn?
I've got a circa 1996 S&S Super E carb on my bike. I downloaded the tuning instructions from their website and had at it a while back. When I got to the part of the tuning where you back the screw out to allow the accelerator pump to begin functioning again, I noticed that instead of it atomizing it's charge of fuel, it seems to kind of spray a sheet of fuel into the throat of the carb. It that how they normally function? Or should it be atomizing the gasoline more? Just wondering if I have an issue here or if that's just how they are.
Thanks for any help!
Al
Big_Cheese is offline   Reply With Quote Quick reply to this message
Old 04-16-2011, 08:55 PM   #2 (permalink)
autoworker's Avatar
autoworker wants to know Dino or Syn?
Look at it this way.The accelerator pump is kind of like a squirt gun.
autoworker is online now   Reply With Quote Quick reply to this message
Old 04-17-2011, 07:32 AM   #3 (permalink)
streetglidekirk's Avatar
streetglidekirk wants to know Dino or Syn?
I put one of these Triple X (XXX) power boosters on my old 98" shovelhead (S&S E). Takes place of the stock emulsion tube. My accelerator pump was adjusted to put just a small amount of gas when throttled. Ran awesome. It had 100 hp/100 tq. I also installed a thunder jet kit.
http://www.xxxcarburetors.com/productpage.html
I'm no expert,but I did stay at a Holiday Inn Express!
2008 Streetglide 103" 10.1:1
Woods TW-555 Cams
Bigboyz street port heads
Doherty Machine Power Pacc Air Breather
Kuryakyn Crusher True Duals
TTS Mastertune
Power Commander V
100 hp 108 tq
L.A. Choppers lowering
Arnott Aldan Air Ride 13" Shocks
Arc Audio KS 125.4 amp
DLS UP6i 6-1/2 speakers
Avatar: The wife and I
streetglidekirk is offline   Reply With Quote Quick reply to this message
Old 04-17-2011, 08:01 AM   #4 (permalink)
0043--Licensed to Doof!
Geezer-Glide's Avatar
Geezer-Glide wants to know Dino or Syn?
S&S carbs work, but they're gas buckets. Yes, that's the way the accelerator pump works, it just hoses fuel in. Adjust it as lean as you can to save your gas mileage.
I ran a XXX Super G on my 103, and it ran like a raped ape. Got tired of the crappy gas mileage, put a Mik 45 on.
Seat, frame, stroker motor, paint, some chrome, two wheels, tires, road grime and a couple of old dead bugs. Fun meter.......PEGGED!!!
I Doof, therefore I am.
D.F.F.D
Geezer-Glide is offline   Reply With Quote Quick reply to this message
Old 04-17-2011, 08:19 AM   #5 (permalink)
True...S&S will drink gas, but will perform well..I tried the mikuni 45 on my 98 fatboy. I just couldnt get it adjusted right. So I went with another S&S E.... I would also tune it a little lean
Woods TW-555 Cams
TTS Mastertune
Power Commander V
100 hp 108 tq
Old 04-17-2011, 10:13 AM   #6 (permalink)
I guess you know that I just gotta get one of those for my Super E now, don'tcha?!
Old 04-17-2011, 02:49 PM   #7 (permalink)
lol.... I hear ya cheese. I felt that the emulsion tube conversion alone helped a lot..... Let us know if you get one and the difference it makes.....
Woods TW-555 Cams
TTS Mastertune
Power Commander V
100 hp 108 tq
Old 04-19-2011, 09:07 AM   #8 (permalink)
Mother's Avatar
Mother wants to know Dino or Syn?
give bob a call at XXXcarbs! I have dealt with him for years now on multiple builds. With his carbs my mileage has been fine
Hyperformance 124ci. 11.5cr CP pistons Triple XXX S&S'G' Green filter
Wood lifters & rocker supports
R&R bottom end DT oil pump. Andrews 64G cams
Torque Inc. JWPERF.com 110 heads
DaytonaTwinTec ignition
Baker KKK/4+1 pan
RB Racing 2" 2into1Blackhole
Smith Bros. pushrods
HUGE amount of help from Torque Inc.
153hp 149tq
JWPERF.COM
Mother is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 09:24 PM   #9 (permalink)
Will do on reporting back, but first I have a question. I have recently installed a Thunderjet on my Super E in the recommended position. Will the emulsion tube of the Thunderjet get in the way of installing the XXX power booster device? I haven't really paid much attention to where the accelerator pump nozzle is located in the carb throat. I could look for myself I guess, but without having that XXX part in hand to look at, I cannot really be sure of if there's room in there for both. What say you?
Old 04-21-2011, 11:30 PM   #10 (permalink)
Mother's Avatar
shouldnt be
Baker KKK/4+1 pan
153hp 149tq
JWPERF.COM
Old 04-22-2011, 09:24 PM   #11 (permalink)
I had a thunderjet on my S&S E with no issuses...The squirter is in the bottom of the throat
Woods TW-555 Cams
TTS Mastertune
Power Commander V
100 hp 108 tq
