Originally Posted by Lowfly
Mikuni card 42mm...... it over flows...not always. and sometimes at idle..sometimes after rideing a few miles.....
Checked the float level..cleaned carb out..bowl is clean. no dirt or anything..'.. It does have a vac line connected to a switch between the cyl...
runs great.just overflows at times..
cant find any reason for it to be overflowing..unless the float is bettin old and sinking....
... whats the switch for?..
It sounds like the tank may not be venting. Inother words, pressure is builing up and forcing fuel out of the overflow. Next time it does that, loosen the fuel cap and see if it stops. Hope that helps.
