BikeBanditCycleGear.comSportbikeTrackGearMotorcycle-CommunicationJardineProducts.comJekillandHyde.euMotorcycle.com Classifieds!Motorcycle.comFuel MotoAmerican Side Road CycleAdvanstarMotorcycleShows
Old 10-10-2009, 09:53 PM   #1 (permalink)
woodwood is on a distinguished road
Carb suggestions?
Going to get rid of my 97' Road King Police stock fuel injection system and replace with carb. Has anyone done this and if so what carb did you replace it with and what are suggestions for a carb.
woodwood is offline   Reply With Quote
Old 10-10-2009, 09:59 PM   #2 (permalink)
The Dyno Man
Steve Handy is on a distinguished road
carb
its hard to beat the stock 40 mm CV....
Steve Handy is offline   Reply With Quote
Old 10-10-2009, 10:17 PM   #3 (permalink)
bigbadal's Avatar
bigbadal is on a distinguished road
My wife and I just got back from a 6,000 mile road trip through 12 western states. We have a 94 ultra and we pulled a 350 plus pound trailer that I built. The engine is still 80 inches and it has a CV carb. We went on the highest continuously paved road in the national park system (12,183 feet) and the lowest paved road (-198 feet). The carb, even though it was running rich in the high elevations, never missed a beat and worked great! In my life, constant velocity is the way to go. Alan
bigbadal is offline   Reply With Quote
Old 10-10-2009, 11:33 PM   #4 (permalink)
strokerjlk's Avatar
+3 on CV
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 10-11-2009, 12:51 AM   #5 (permalink)
LowRiderCustom's Avatar
LowRiderCustom is on a distinguished road
After talking with my brother and other Harley guys, I'm going with a Mikuni carb. They are easier to tune and the bike runs so much better with it. I've changed jets on the CV many times and I still can't get it to run perfect throughout the whole RPM range.
LowRiderCustom is offline   Reply With Quote
Old 10-11-2009, 02:28 AM   #6 (permalink)
Masonman's Avatar
Masonman is on a distinguished road
One question, what did the lines look like in your tank. Im at the end of a swap myself and have the pingle MM plug/adapter and fuel valve. One check valve came out when I pulled the lines but I cant get the other out. I looked in the tank and they are steel lines and appear to be welded in.. Is this right?!?! Its a 99RK. I have a Thunder Heart Ign. and polished 42 Mikuni mounted. let me know what your tank looked like inside.. thanks
1999 RKC
AMS heads,AMS 96 BB
KB flat tops,9.8-1
37G's,2to1 FatCat
SE manifold, Mikuni 42
Thuderheart Ign.
Arlen Ness Big Sucker
Masonman is offline   Reply With Quote
Old 10-11-2009, 02:31 AM   #7 (permalink)
Masonman's Avatar
PS.. I have an HPI 48 to sell...It was on the bike a couple of months but I couldnt case down why it was dropping the front injector..Tired of messing with the MM..
1999 RKC
AMS heads,AMS 96 BB
KB flat tops,9.8-1
37G's,2to1 FatCat
Thuderheart Ign.
Old 10-11-2009, 03:33 PM   #8 (permalink)
Formerly 04GLIDE
03GLIDE_'s Avatar
I'd go with a 40mm CV
03GLIDE_ is online now   Reply With Quote
Old 10-11-2009, 09:58 PM   #9 (permalink)
gsxrboy96's Avatar
The cv is a much better carb than the mikuni.... ive done back to back dyno runs with the two and the cv actually makes more torque but sacrafices peak hp(which doesnt matter). What is done to your bike and what size jets are you running? what needle?
Old 10-11-2009, 11:15 PM   #10 (permalink)
It has V&H Bigshots and an unknown aftermarket cam that was in the motor when I bought the bike, with a Hypercharger air cleaner. My buddy at the local custom Harley shop swapped jets a couple times so I have no idea whats in there now. It runs good but it pops coming off the throttle at high RPM's. I installed new intake/carb/exhaust gaskets so it's not that, so I figure it's the carb settings.
Old 10-12-2009, 10:36 AM   #11 (permalink)
Jonny A is on a distinguished road
I've got an 05 FLHT with a stock CV and it works well. No problems here. Toured a few different elevations and other than oil blow by, which has nothing to do with the carb, it was fine.
Jonny A is offline   Reply With Quote
Old 10-12-2009, 11:53 AM   #12 (permalink)
No offense meant but it sounds like you just need to get your cv sorted. without knowing what cam you have you may have a mismatched cam for your build. also just because you put new gaskets on does not mean they are not leaking. just throwing jets in without knowing what is going on is not a great solution.
Mtclassic is online now   Reply With Quote
Old 10-12-2009, 07:48 PM   #13 (permalink)
gsxrboy96's Avatar
usually if its popping, the bike is fat, without knowing what cam its hard to recommend something, a bolt on mikuni may and may not cure your issues, I do know the cv can be tuned to not do that, you just have to have someone familiar enough with trial and error. also do your pipes have any baffles? chad.
Old 10-12-2009, 08:53 PM   #14 (permalink)
The guy at the local custom Harley shop read the plugs, so it's dialed in to the correct mixture. I do have a blown base gasket, maybe that's where it's sucking air.
Old 11-08-2009, 03:10 AM   #15 (permalink)
mator57 is on a distinguished road
to th first that is going from efi to carb. the mikuni is a finer tuned carb but th s&s is much eiser th repair down th road if by some reason it gets to haven problems and it can make great power and fuel ecom, if tuned. th factory carb just dont have enuff screws.
i am also gathering parts to change out my 97 efi to s&S. i know pretty much th carb, intake etc. what i want to know is what is th best way to go on th elec ign so i dont have to spend time with hot oil blown in my face timing it. i put crane h4 in th lod sofetail i have. th efi has a crank sensorthat knows when top dead is there. i what th name of a good dependable yet cost effective ing. thanks to you all in advance as you may reply. it takes time to read and to answr.!
mator57 is offline   Reply With Quote
