Bad CV carburetor
OK long story short. 98 Lowrider 1340 started running ragged at any steady speed. I replaced plugs,wires,coil, rebuilt the carb, drained gas(twice), replaced fuel line, petcock and cleaned the K&N air filter thoroughly. When I put new plugs in it, it runs great for about 30 miles then does the same thing! Fouls the plugs with gas not oil. They are smut black and dry.
I finally threw in the towel and took it to a local shop. He kept the bike for 2 weeks, then called and said it was fixed. 25 miles later, same thing. I marked the bolts on the air cleaner when I put everything back together the last time to see what the shop would check. Nothing has moved except they changed the plugs. When I called to tell them it wan't fixed, they said the carb was bad and needed replacing. Do the carbs go bad or do they just need rejetting? Thanks.....................
